drivers: CCI: Correct use of ! and &
Author: Himangi Saraogi <himangi774@gmail.com>
In commit ae91d60ba88ef0bdb1b5e9b2363bd52fc45d2af7, a bug was fixed that
involved converting !x & y to !(x & y). The code below shows the same
pattern, and thus should perhaps be fixed in the same way.
The Coccinelle semantic patch that makes this change is as follows:
@@ expression E1,E2; @@
!E1 & !E2
- !E1 & E2
+ !(E1 & E2)
Signed-off-by: Himangi Saraogi
Acked-by: Julia Lawall
Acked-by: Punit Agrawal
Signed-off-by: Olof Johansson
drivers/bus/arm-cci.c | 3 ++-
1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/bus/arm-cci.c b/drivers/bus/arm-cci.c
index 5a86da9..7af78df 100644
--- a/drivers/bus/arm-cci.c
+++ b/drivers/bus/arm-cci.c
@@ -397,7 +397,8 @@ static irqreturn_t pmu_handle_irq(int irq_num, void *dev)
hw_counter = &event->hw;
/* Did this counter overflow? */
- if (!pmu_read_register(idx, CCI_PMU_OVRFLW) & CCI_PMU_OVRFLW_FLAG)
+ if (!(pmu_read_register(idx, CCI_PMU_OVRFLW) &
+ CCI_PMU_OVRFLW_FLAG))
continue;
pmu_write_register(CCI_PMU_OVRFLW_FLAG, idx, CCI_PMU_OVRFLW); |
continue;
