driver core: Delete an unnecessary check before the function call “put_device”
Author: Markus Elfring <elfring@users.sourceforge.net>
The put_device() function tests whether its argument is NULL and then
returns immediately. Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
 drivers/base/core.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/base/core.c b/drivers/base/core.c
index 07304a3..e0998b6 100644
--- a/drivers/base/core.c
+++ b/drivers/base/core.c
@@ -1095,8 +1095,7 @@ done:
 	kobject_del(&dev->kobj);
  Error:
 	cleanup_device_parent(dev);
-	if (parent)
-		put_device(parent);
+	put_device(parent);
 name_error:
 	kfree(dev->p);
 	dev->p = NULL;
BtrLinux
Privacy Overview
