drbd: Deletion of an unnecessary check before the function call “lc_destroy”
Author: Markus Elfring <elfring@users.sourceforge.net>
The lc_destroy() function tests whether its argument is NULL and then
returns immediately. Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Roland Kammerer
Signed-off-by: Philipp Reisner
Signed-off-by: Lars Ellenberg
Signed-off-by: Jens Axboe
 drivers/block/drbd/drbd_nl.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/block/drbd/drbd_nl.c b/drivers/block/drbd/drbd_nl.c
index 1eb10e2..b87fb31 100644
--- a/drivers/block/drbd/drbd_nl.c
+++ b/drivers/block/drbd/drbd_nl.c
@@ -1133,8 +1133,7 @@ static int drbd_check_al_size(struct drbd_device *device, struct disk_conf *dc)
 		lc_destroy(n);
 		return -EBUSY;
 	} else {
-		if (t)
-			lc_destroy(t);
+		lc_destroy(t);
 	drbd_md_mark_dirty(device); /* we changed device->act_log->nr_elemens */
 	return 0;
BtrLinux
Privacy Overview
