dmfe: fix misspelling of current function in string
Author: Julia Lawall <julia.lawall@lip6.fr>
The function name contains cleanup, not clean.
This was done using Coccinelle, including the use of Levenshtein distance,
as proposed by Rasmus Villemoes.
Signed-off-by: Julia Lawall
Acked-by: Grant Grundler
Signed-off-by: David S. Miller
drivers/net/ethernet/dec/tulip/dmfe.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/ethernet/dec/tulip/dmfe.c b/drivers/net/ethernet/dec/tulip/dmfe.c
index c820560..50a0077 100644
--- a/drivers/net/ethernet/dec/tulip/dmfe.c
+++ b/drivers/net/ethernet/dec/tulip/dmfe.c
@@ -2265,7 +2265,7 @@ static int __init dmfe_init_module(void)
static void __exit dmfe_cleanup_module(void)
- DMFE_DBUG(0, "dmfe_clean_module() ", debug);
+ DMFE_DBUG(0, "dmfe_cleanup_module() ", debug);
pci_unregister_driver(&dmfe_driver);
