dmaengine: xgene-dma: fix handling xgene_dma_get_ring_size result
Author: Andrzej Hajda <a.hajda@samsung.com>
The function can return negative value.
The problem has been detected using proposed semantic patch
scripts/coccinelle/tests/assign_signed_to_unsigned.cocci [1].
[1]: http://permalink.gmane.org/gmane.linux.kernel/2046107
Signed-off-by: Andrzej Hajda
Signed-off-by: Vinod Koul
drivers/dma/xgene-dma.c | 9 ++++++---
1 file changed, 6 insertions(+), 3 deletions(-)
diff --git a/drivers/dma/xgene-dma.c b/drivers/dma/xgene-dma.c
index b23e8d5..4c5ddda 100644
--- a/drivers/dma/xgene-dma.c
+++ b/drivers/dma/xgene-dma.c
@@ -1421,15 +1421,18 @@ static int xgene_dma_create_ring_one(struct xgene_dma_chan *chan,
struct xgene_dma_ring *ring,
enum xgene_dma_ring_cfgsize cfgsize)
+ int ret;
/* Setup DMA ring descriptor variables */
ring->pdma = chan->pdma;
ring->cfgsize = cfgsize;
ring->num = chan->pdma->ring_num++;
ring->id = XGENE_DMA_RING_ID_GET(ring->owner, ring->buf_num);
- ring->size = xgene_dma_get_ring_size(chan, cfgsize);
- if (ring->size <= 0)
- return ring->size;
+ ret = xgene_dma_get_ring_size(chan, cfgsize);
+ if (ret <= 0)
+ return ret;
+ ring->size = ret;
/* Allocate memory for DMA ring descriptor */
ring->desc_vaddr = dma_zalloc_coherent(chan->dev, ring->size, |
+ int ret;
+ if (ret <= 0)
+ return ret;
+ ring->size = ret;
