dmaengine: ipu: Prepare irq handlers for irq argument removal
Author: Thomas Gleixner <tglx@linutronix.de>
The irq argument of most interrupt flow handlers is unused or merily
used instead of a local variable. The handlers which need the irq
argument can retrieve the irq number from the irq descriptor.
Search and update was done with coccinelle and the invaluable help of
Julia Lawall.
Signed-off-by: Thomas Gleixner
Cc: Julia Lawall
Cc: Vinod Koul
Cc: Dan Williams
Cc: dmaengine@vger.kernel.org
Signed-off-by: Vinod Koul
drivers/dma/ipu/ipu_irq.c | 6 ++++--
1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/drivers/dma/ipu/ipu_irq.c b/drivers/dma/ipu/ipu_irq.c
index 4357063..9f95940 100644
--- a/drivers/dma/ipu/ipu_irq.c
+++ b/drivers/dma/ipu/ipu_irq.c
@@ -266,7 +266,7 @@ int ipu_irq_unmap(unsigned int source)
/* Chained IRQ handler for IPU error interrupt */
-static void ipu_irq_err(unsigned int irq, struct irq_desc *desc)
+static void ipu_irq_err(unsigned int __irq, struct irq_desc *desc)
struct ipu *ipu = irq_desc_get_handler_data(desc);
u32 status;
@@ -286,6 +286,7 @@ static void ipu_irq_err(unsigned int irq, struct irq_desc *desc)
raw_spin_unlock(&bank_lock);
while ((line = ffs(status))) {
struct ipu_irq_map *map;
+ unsigned int irq;
line--;
status &= ~(1UL << line);
@@ -307,7 +308,7 @@ static void ipu_irq_err(unsigned int irq, struct irq_desc *desc)
/* Chained IRQ handler for IPU function interrupt */
-static void ipu_irq_fn(unsigned int irq, struct irq_desc *desc)
+static void ipu_irq_fn(unsigned int __irq, struct irq_desc *desc)
u32 status;
@@ -323,6 +324,7 @@ static void ipu_irq_fn(unsigned int irq, struct irq_desc *desc)
+ unsigned int irq;
line--;
status &= ~(1UL << line); |
u32 status;
+ unsigned int irq;
line--;
u32 status;
+ unsigned int irq;
line--;
