dmaengine: ioatdma: Use dma_pool_zalloc
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Dma_pool_zalloc combines dma_pool_alloc and memset 0. The semantic patch
that makes this transformation is as follows: (http://coccinelle.lip6.fr/)
expression d,e;
statement S;
d =
- dma_pool_alloc
+ dma_pool_zalloc
if (!d) S
- memset(d, 0, sizeof(*d));
Signed-off-by: Julia Lawall
Signed-off-by: Vinod Koul
drivers/dma/ioat/init.c | 5 ++---
1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/drivers/dma/ioat/init.c b/drivers/dma/ioat/init.c
index efdee1a..d4c63d4 100644
--- a/drivers/dma/ioat/init.c
+++ b/drivers/dma/ioat/init.c
@@ -690,12 +690,11 @@ static int ioat_alloc_chan_resources(struct dma_chan *c)
/* allocate a completion writeback area */
/* doing 2 32bit writes to mmio since 1 64b write doesn't work */
ioat_chan->completion =
- dma_pool_alloc(ioat_chan->ioat_dma->completion_pool,
- GFP_KERNEL, &ioat_chan->completion_dma);
+ dma_pool_zalloc(ioat_chan->ioat_dma->completion_pool,
+ GFP_KERNEL, &ioat_chan->completion_dma);
if (!ioat_chan->completion)
return -ENOMEM;
- memset(ioat_chan->completion, 0, sizeof(*ioat_chan->completion));
writel(((u64)ioat_chan->completion_dma) & 0x00000000FFFFFFFF,
ioat_chan->reg_base + IOAT_CHANCMP_OFFSET_LOW);
writel(((u64)ioat_chan->completion_dma) >> 32, |
return -ENOMEM;
