dma, mm/pat: Rename dma_*_writecombine() to dma_*_wc()
Author: Luis R. Rodriguez <mcgrof@suse.com>
Rename dma_*_writecombine() to dma_*_wc(), so that the naming
is coherent across the various write-combining APIs. Keep the
old names for compatibility for a while, these can be removed
at a later time. A guard is left to enable backporting of the
rename, and later remove of the old mapping defines seemlessly.
Build tested successfully with allmodconfig.
The following Coccinelle SmPL patch was used for this simple
transformation:
@ rename_dma_alloc_writecombine @
expression dev, size, dma_addr, gfp;
-dma_alloc_writecombine(dev, size, dma_addr, gfp)
+dma_alloc_wc(dev, size, dma_addr, gfp)
@ rename_dma_free_writecombine @
expression dev, size, cpu_addr, dma_addr;
-dma_free_writecombine(dev, size, cpu_addr, dma_addr)
+dma_free_wc(dev, size, cpu_addr, dma_addr)
@ rename_dma_mmap_writecombine @
expression dev, vma, cpu_addr, dma_addr, size;
-dma_mmap_writecombine(dev, vma, cpu_addr, dma_addr, size)
+dma_mmap_wc(dev, vma, cpu_addr, dma_addr, size)
We also keep the old names as compatibility helpers, and
guard against their definition to make backporting easier.
Generated-by: Coccinelle SmPL
Suggested-by: Ingo Molnar
Signed-off-by: Luis R. Rodriguez
Cc: Linus Torvalds
Cc: Peter Zijlstra
Cc: Thomas Gleixner
Cc: airlied@linux.ie
Cc: akpm@linux-foundation.org
Cc: benh@kernel.crashing.org
Cc: bhelgaas@google.com
Cc: bp@suse.de
Cc: dan.j.williams@intel.com
Cc: daniel.vetter@ffwll.ch
Cc: dhowells@redhat.com
Cc: julia.lawall@lip6.fr
Cc: konrad.wilk@oracle.com
Cc: linux-fbdev@vger.kernel.org
Cc: linux-pci@vger.kernel.org
Cc: luto@amacapital.net
Cc: mst@redhat.com
Cc: tomi.valkeinen@ti.com
Cc: toshi.kani@hp.com
Cc: vinod.koul@intel.com
Cc: xen-devel@lists.xensource.com
Link: http://lkml.kernel.org/r/1453516462-4844-1-git-send-email-mcgrof@do-not-panic.com
Signed-off-by: Ingo Molnar
 arch/arm/mach-lpc32xx/phy3250.c           | 13 ++++++-------
 arch/arm/mach-netx/fb.c                   | 14 ++++++--------
 arch/arm/mach-nspire/clcd.c               | 13 ++++++-------
 drivers/dma/iop-adma.c                    |  8 ++++----
 drivers/dma/mv_xor.c                      |  4 ++--
 drivers/dma/qcom_bam_dma.c                | 14 +++++++-------
 drivers/gpu/drm/drm_gem_cma_helper.c      | 13 ++++++-------
 drivers/gpu/drm/etnaviv/etnaviv_gpu.c     |  8 ++++----
 drivers/gpu/drm/omapdrm/omap_dmm_tiler.c  | 13 ++++++-------
 drivers/gpu/drm/omapdrm/omap_gem.c        |  8 ++++----
 drivers/gpu/drm/sti/sti_cursor.c          | 20 +++++++++-----------
 drivers/gpu/drm/sti/sti_gdp.c             |  3 +--
 drivers/gpu/drm/sti/sti_hqvdp.c           |  6 +++---
 drivers/gpu/drm/tegra/gem.c               | 11 +++++------
 drivers/gpu/drm/vc4/vc4_bo.c              |  5 ++---
 drivers/gpu/host1x/cdma.c                 |  8 ++++----
 drivers/gpu/host1x/job.c                  | 10 ++++------
 drivers/media/platform/coda/coda-bit.c    | 10 +++++-----
 drivers/video/fbdev/acornfb.c             |  4 ++--
 drivers/video/fbdev/amba-clcd-versatile.c | 14 ++++++--------
 drivers/video/fbdev/amba-clcd.c           |  4 ++--
 drivers/video/fbdev/atmel_lcdfb.c         |  9 +++++----
 drivers/video/fbdev/ep93xx-fb.c           |  8 +++-----
 drivers/video/fbdev/gbefb.c               |  8 ++++----
 drivers/video/fbdev/imxfb.c               | 12 ++++++------
 drivers/video/fbdev/mx3fb.c               |  9 ++++-----
 drivers/video/fbdev/nuc900fb.c            |  8 ++++----
 drivers/video/fbdev/omap/lcdc.c           | 16 ++++++++--------
 drivers/video/fbdev/pxa168fb.c            |  8 ++++----
 drivers/video/fbdev/pxafb.c               |  4 ++--
 drivers/video/fbdev/s3c-fb.c              |  7 +++----
 drivers/video/fbdev/s3c2410fb.c           |  8 ++++----
 drivers/video/fbdev/sa1100fb.c            |  8 ++++----
 include/linux/dma-mapping.h               | 25 +++++++++++++++++--------
 sound/arm/pxa2xx-pcm-lib.c                | 12 ++++--------
 sound/soc/fsl/imx-pcm-fiq.c               | 10 ++++------
 sound/soc/nuc900/nuc900-pcm.c             |  6 ++----
 sound/soc/omap/omap-pcm.c                 | 12 ++++--------
 38 files changed, 176 insertions(+), 197 deletions(-)
diff --git a/arch/arm/mach-lpc32xx/phy3250.c b/arch/arm/mach-lpc32xx/phy3250.c
index 77d6b1b..ee06fab 100644
--- a/arch/arm/mach-lpc32xx/phy3250.c
+++ b/arch/arm/mach-lpc32xx/phy3250.c
@@ -86,8 +86,8 @@ static int lpc32xx_clcd_setup(struct clcd_fb *fb)
 	dma_addr_t dma;
-	fb->fb.screen_base = dma_alloc_writecombine(&fb->dev->dev,
-		PANEL_SIZE, &dma, GFP_KERNEL);
+	fb->fb.screen_base = dma_alloc_wc(&fb->dev->dev, PANEL_SIZE, &dma,
+					  GFP_KERNEL);
 	if (!fb->fb.screen_base) {
 		printk(KERN_ERR "CLCD: unable to map framebuffer\n");
 		return -ENOMEM;
@@ -116,15 +116,14 @@ static int lpc32xx_clcd_setup(struct clcd_fb *fb)
 static int lpc32xx_clcd_mmap(struct clcd_fb *fb, struct vm_area_struct *vma)
-	return dma_mmap_writecombine(&fb->dev->dev, vma,
-		fb->fb.screen_base, fb->fb.fix.smem_start,
-		fb->fb.fix.smem_len);
+	return dma_mmap_wc(&fb->dev->dev, vma, fb->fb.screen_base,
+			   fb->fb.fix.smem_start, fb->fb.fix.smem_len);
 static void lpc32xx_clcd_remove(struct clcd_fb *fb)
-	dma_free_writecombine(&fb->dev->dev, fb->fb.fix.smem_len,
-		fb->fb.screen_base, fb->fb.fix.smem_start);
+	dma_free_wc(&fb->dev->dev, fb->fb.fix.smem_len, fb->fb.screen_base,
+		    fb->fb.fix.smem_start);
diff --git a/arch/arm/mach-netx/fb.c b/arch/arm/mach-netx/fb.c
index d122ee6..8814ee5 100644
--- a/arch/arm/mach-netx/fb.c
+++ b/arch/arm/mach-netx/fb.c
@@ -42,8 +42,8 @@ int netx_clcd_setup(struct clcd_fb *fb)
 	fb->panel = netx_panel;
-	fb->fb.screen_base = dma_alloc_writecombine(&fb->dev->dev, 1024*1024,
-						    &dma, GFP_KERNEL);
+	fb->fb.screen_base = dma_alloc_wc(&fb->dev->dev, 1024 * 1024, &dma,
+					  GFP_KERNEL);
 		return -ENOMEM;
@@ -57,16 +57,14 @@ int netx_clcd_setup(struct clcd_fb *fb)
 int netx_clcd_mmap(struct clcd_fb *fb, struct vm_area_struct *vma)
-				     fb->fb.fix.smem_start,
 void netx_clcd_remove(struct clcd_fb *fb)
 static AMBA_AHB_DEVICE(fb, "fb", 0, 0x00104000, { NETX_IRQ_LCD }, NULL);
diff --git a/arch/arm/mach-nspire/clcd.c b/arch/arm/mach-nspire/clcd.c
index abea126..ea0e5b2 100644
--- a/arch/arm/mach-nspire/clcd.c
+++ b/arch/arm/mach-nspire/clcd.c
@@ -90,8 +90,8 @@ int nspire_clcd_setup(struct clcd_fb *fb)
 	panel_size = ((panel->mode.xres * panel->mode.yres) * panel->bpp) / 8;
 	panel_size = ALIGN(panel_size, PAGE_SIZE);
-		panel_size, &dma, GFP_KERNEL);
+	fb->fb.screen_base = dma_alloc_wc(&fb->dev->dev, panel_size, &dma,
+					  GFP_KERNEL);
 		pr_err("CLCD: unable to map framebuffer\n");
@@ -107,13 +107,12 @@ int nspire_clcd_setup(struct clcd_fb *fb)
 int nspire_clcd_mmap(struct clcd_fb *fb, struct vm_area_struct *vma)
 void nspire_clcd_remove(struct clcd_fb *fb)
diff --git a/drivers/dma/iop-adma.c b/drivers/dma/iop-adma.c
index e4f4312..f039cfa 100644
--- a/drivers/dma/iop-adma.c
+++ b/drivers/dma/iop-adma.c
@@ -1300,10 +1300,10 @@ static int iop_adma_probe(struct platform_device *pdev)
 	 * note: writecombine gives slightly better performance, but
 	 * requires that we explicitly flush the writes
-	adev->dma_desc_pool_virt = dma_alloc_writecombine(&pdev->dev,
-							  plat_data->pool_size,
-							  &adev->dma_desc_pool,
-							  GFP_KERNEL);
+	adev->dma_desc_pool_virt = dma_alloc_wc(&pdev->dev,
+						plat_data->pool_size,
+						&adev->dma_desc_pool,
+						GFP_KERNEL);
 	if (!adev->dma_desc_pool_virt) {
 		ret = -ENOMEM;
 		goto err_free_adev;
diff --git a/drivers/dma/mv_xor.c b/drivers/dma/mv_xor.c
index 14091f8..3922a5d 100644
--- a/drivers/dma/mv_xor.c
+++ b/drivers/dma/mv_xor.c
@@ -964,8 +964,8 @@ mv_xor_channel_add(struct mv_xor_device *xordev,
 	mv_chan->dma_desc_pool_virt =
-	  dma_alloc_writecombine(&pdev->dev, MV_XOR_POOL_SIZE,
-				 &mv_chan->dma_desc_pool, GFP_KERNEL);
+	  dma_alloc_wc(&pdev->dev, MV_XOR_POOL_SIZE, &mv_chan->dma_desc_pool,
+		       GFP_KERNEL);
 	if (!mv_chan->dma_desc_pool_virt)
 		return ERR_PTR(-ENOMEM);
diff --git a/drivers/dma/qcom_bam_dma.c b/drivers/dma/qcom_bam_dma.c
index 5a250cd..d34aef7 100644
--- a/drivers/dma/qcom_bam_dma.c
+++ b/drivers/dma/qcom_bam_dma.c
@@ -502,8 +502,8 @@ static int bam_alloc_chan(struct dma_chan *chan)
 		return 0;
 	/* allocate FIFO descriptor space, but only if necessary */
-	bchan->fifo_virt = dma_alloc_writecombine(bdev->dev, BAM_DESC_FIFO_SIZE,
-				&bchan->fifo_phys, GFP_KERNEL);
+	bchan->fifo_virt = dma_alloc_wc(bdev->dev, BAM_DESC_FIFO_SIZE,
+					&bchan->fifo_phys, GFP_KERNEL);
 	if (!bchan->fifo_virt) {
 		dev_err(bdev->dev, "Failed to allocate desc fifo\n");
@@ -538,8 +538,8 @@ static void bam_free_chan(struct dma_chan *chan)
 	bam_reset_channel(bchan);
 	spin_unlock_irqrestore(&bchan->vc.lock, flags);
-	dma_free_writecombine(bdev->dev, BAM_DESC_FIFO_SIZE, bchan->fifo_virt,
-				bchan->fifo_phys);
+	dma_free_wc(bdev->dev, BAM_DESC_FIFO_SIZE, bchan->fifo_virt,
+		    bchan->fifo_phys);
 	bchan->fifo_virt = NULL;
 	/* mask irq for pipe/channel */
@@ -1231,9 +1231,9 @@ static int bam_dma_remove(struct platform_device *pdev)
 		bam_dma_terminate_all(&bdev->channels[i].vc.chan);
 		tasklet_kill(&bdev->channels[i].vc.task);
-			bdev->channels[i].fifo_virt,
-			bdev->channels[i].fifo_phys);
+			    bdev->channels[i].fifo_virt,
+			    bdev->channels[i].fifo_phys);
 	tasklet_kill(&bdev->task);
diff --git a/drivers/gpu/drm/drm_gem_cma_helper.c b/drivers/gpu/drm/drm_gem_cma_helper.c
index e5df53b..1f500a1 100644
--- a/drivers/gpu/drm/drm_gem_cma_helper.c
+++ b/drivers/gpu/drm/drm_gem_cma_helper.c
@@ -109,8 +109,8 @@ struct drm_gem_cma_object *drm_gem_cma_create(struct drm_device *drm,
 	if (IS_ERR(cma_obj))
 		return cma_obj;
-	cma_obj->vaddr = dma_alloc_writecombine(drm->dev, size,
-			&cma_obj->paddr, GFP_KERNEL | __GFP_NOWARN);
+	cma_obj->vaddr = dma_alloc_wc(drm->dev, size, &cma_obj->paddr,
+				      GFP_KERNEL | __GFP_NOWARN);
 	if (!cma_obj->vaddr) {
 		dev_err(drm->dev, "failed to allocate buffer with size %zu\n",
 			size);
@@ -192,8 +192,8 @@ void drm_gem_cma_free_object(struct drm_gem_object *gem_obj)
 	cma_obj = to_drm_gem_cma_obj(gem_obj);
 	if (cma_obj->vaddr) {
-		dma_free_writecombine(gem_obj->dev->dev, cma_obj->base.size,
-				      cma_obj->vaddr, cma_obj->paddr);
+		dma_free_wc(gem_obj->dev->dev, cma_obj->base.size,
+			    cma_obj->vaddr, cma_obj->paddr);
 	} else if (gem_obj->import_attach) {
 		drm_prime_gem_destroy(gem_obj, cma_obj->sgt);
@@ -324,9 +324,8 @@ static int drm_gem_cma_mmap_obj(struct drm_gem_cma_object *cma_obj,
 	vma->vm_flags &= ~VM_PFNMAP;
 	vma->vm_pgoff = 0;
-	ret = dma_mmap_writecombine(cma_obj->base.dev->dev, vma,
-				    cma_obj->vaddr, cma_obj->paddr,
-				    vma->vm_end - vma->vm_start);
+	ret = dma_mmap_wc(cma_obj->base.dev->dev, vma, cma_obj->vaddr,
+			  cma_obj->paddr, vma->vm_end - vma->vm_start);
 	if (ret)
 		drm_gem_vm_close(vma);
diff --git a/drivers/gpu/drm/etnaviv/etnaviv_gpu.c b/drivers/gpu/drm/etnaviv/etnaviv_gpu.c
index a33162c..3c1ce44 100644
--- a/drivers/gpu/drm/etnaviv/etnaviv_gpu.c
+++ b/drivers/gpu/drm/etnaviv/etnaviv_gpu.c
@@ -1113,8 +1113,8 @@ struct etnaviv_cmdbuf *etnaviv_gpu_cmdbuf_new(struct etnaviv_gpu *gpu, u32 size,
 	if (!cmdbuf)
 		return NULL;
-	cmdbuf->vaddr = dma_alloc_writecombine(gpu->dev, size, &cmdbuf->paddr,
-					       GFP_KERNEL);
+	cmdbuf->vaddr = dma_alloc_wc(gpu->dev, size, &cmdbuf->paddr,
+				     GFP_KERNEL);
 	if (!cmdbuf->vaddr) {
 		kfree(cmdbuf);
 		return NULL;
@@ -1128,8 +1128,8 @@ struct etnaviv_cmdbuf *etnaviv_gpu_cmdbuf_new(struct etnaviv_gpu *gpu, u32 size,
 void etnaviv_gpu_cmdbuf_free(struct etnaviv_cmdbuf *cmdbuf)
-	dma_free_writecombine(cmdbuf->gpu->dev, cmdbuf->size,
-			      cmdbuf->vaddr, cmdbuf->paddr);
+	dma_free_wc(cmdbuf->gpu->dev, cmdbuf->size, cmdbuf->vaddr,
+		    cmdbuf->paddr);
 	kfree(cmdbuf);
diff --git a/drivers/gpu/drm/omapdrm/omap_dmm_tiler.c b/drivers/gpu/drm/omapdrm/omap_dmm_tiler.c
index dfebdc4..85dfe36 100644
--- a/drivers/gpu/drm/omapdrm/omap_dmm_tiler.c
+++ b/drivers/gpu/drm/omapdrm/omap_dmm_tiler.c
@@ -573,10 +573,9 @@ static int omap_dmm_remove(struct platform_device *dev)
 		kfree(omap_dmm->engines);
 		if (omap_dmm->refill_va)
-			dma_free_writecombine(omap_dmm->dev,
-				REFILL_BUFFER_SIZE * omap_dmm->num_engines,
-				omap_dmm->refill_va,
-				omap_dmm->refill_pa);
+			dma_free_wc(omap_dmm->dev,
+				    REFILL_BUFFER_SIZE * omap_dmm->num_engines,
+				    omap_dmm->refill_va, omap_dmm->refill_pa);
 		if (omap_dmm->dummy_page)
 			__free_page(omap_dmm->dummy_page);
@@ -701,9 +700,9 @@ static int omap_dmm_probe(struct platform_device *dev)
 	omap_dmm->dummy_pa = page_to_phys(omap_dmm->dummy_page);
 	/* alloc refill memory */
-	omap_dmm->refill_va = dma_alloc_writecombine(&dev->dev,
-				&omap_dmm->refill_pa, GFP_KERNEL);
+	omap_dmm->refill_va = dma_alloc_wc(&dev->dev,
+					   &omap_dmm->refill_pa, GFP_KERNEL);
 	if (!omap_dmm->refill_va) {
 		dev_err(&dev->dev, "could not allocate refill memory\n");
 		goto fail;
diff --git a/drivers/gpu/drm/omapdrm/omap_gem.c b/drivers/gpu/drm/omapdrm/omap_gem.c
index 8495a1a..359b0d7 100644
--- a/drivers/gpu/drm/omapdrm/omap_gem.c
+++ b/drivers/gpu/drm/omapdrm/omap_gem.c
@@ -1330,8 +1330,8 @@ void omap_gem_free_object(struct drm_gem_object *obj)
 			omap_gem_detach_pages(obj);
 		if (!is_shmem(obj)) {
-			dma_free_writecombine(dev->dev, obj->size,
-					omap_obj->vaddr, omap_obj->paddr);
+			dma_free_wc(dev->dev, obj->size, omap_obj->vaddr,
+				    omap_obj->paddr);
 		} else if (omap_obj->vaddr) {
 			vunmap(omap_obj->vaddr);
@@ -1395,8 +1395,8 @@ struct drm_gem_object *omap_gem_new(struct drm_device *dev,
 		/* attempt to allocate contiguous memory if we don't
 		 * have DMM for remappign discontiguous buffers
-		omap_obj->vaddr =  dma_alloc_writecombine(dev->dev, size,
-				&omap_obj->paddr, GFP_KERNEL);
+		omap_obj->vaddr =  dma_alloc_wc(dev->dev, size,
+						&omap_obj->paddr, GFP_KERNEL);
 		if (!omap_obj->vaddr) {
 			kfree(omap_obj);
diff --git a/drivers/gpu/drm/sti/sti_cursor.c b/drivers/gpu/drm/sti/sti_cursor.c
index 8078631..bd736ac 100644
--- a/drivers/gpu/drm/sti/sti_cursor.c
+++ b/drivers/gpu/drm/sti/sti_cursor.c
@@ -157,17 +157,15 @@ static void sti_cursor_atomic_update(struct drm_plane *drm_plane,
 		cursor->height = src_h;
 		if (cursor->pixmap.base)
-			dma_free_writecombine(cursor->dev,
-					      cursor->pixmap.size,
-					      cursor->pixmap.base,
-					      cursor->pixmap.paddr);
+			dma_free_wc(cursor->dev, cursor->pixmap.size,
+				    cursor->pixmap.base, cursor->pixmap.paddr);
 		cursor->pixmap.size = cursor->width * cursor->height;
-		cursor->pixmap.base = dma_alloc_writecombine(cursor->dev,
-							&cursor->pixmap.paddr,
-							GFP_KERNEL | GFP_DMA);
+		cursor->pixmap.base = dma_alloc_wc(cursor->dev,
+						   cursor->pixmap.size,
+						   &cursor->pixmap.paddr,
+						   GFP_KERNEL | GFP_DMA);
 		if (!cursor->pixmap.base) {
 			DRM_ERROR("Failed to allocate memory for pixmap\n");
 			return;
@@ -252,8 +250,8 @@ struct drm_plane *sti_cursor_create(struct drm_device *drm_dev,
 	/* Allocate clut buffer */
 	size = 0x100 * sizeof(unsigned short);
-	cursor->clut = dma_alloc_writecombine(dev, size, &cursor->clut_paddr,
+	cursor->clut = dma_alloc_wc(dev, size, &cursor->clut_paddr,
 	if (!cursor->clut) {
 		DRM_ERROR("Failed to allocate memory for cursor clut\n");
@@ -286,7 +284,7 @@ struct drm_plane *sti_cursor_create(struct drm_device *drm_dev,
 	return &cursor->plane.drm_plane;
 err_plane:
-	dma_free_writecombine(dev, size, cursor->clut, cursor->clut_paddr);
+	dma_free_wc(dev, size, cursor->clut, cursor->clut_paddr);
 err_clut:
 	devm_kfree(dev, cursor);
 	return NULL;
diff --git a/drivers/gpu/drm/sti/sti_gdp.c b/drivers/gpu/drm/sti/sti_gdp.c
index f9a1d92..514551c 100644
--- a/drivers/gpu/drm/sti/sti_gdp.c
+++ b/drivers/gpu/drm/sti/sti_gdp.c
@@ -312,8 +312,7 @@ static void sti_gdp_init(struct sti_gdp *gdp)
 	/* Allocate all the nodes within a single memory page */
 	size = sizeof(struct sti_gdp_node) *
 	    GDP_NODE_PER_FIELD * GDP_NODE_NB_BANK;
-	base = dma_alloc_writecombine(gdp->dev,
-				      size, &dma_addr, GFP_KERNEL | GFP_DMA);
+	base = dma_alloc_wc(gdp->dev, size, &dma_addr, GFP_KERNEL | GFP_DMA);
 	if (!base) {
 		DRM_ERROR("Failed to allocate memory for GDP node\n");
diff --git a/drivers/gpu/drm/sti/sti_hqvdp.c b/drivers/gpu/drm/sti/sti_hqvdp.c
index 43861b5..1d3c3d0 100644
--- a/drivers/gpu/drm/sti/sti_hqvdp.c
+++ b/drivers/gpu/drm/sti/sti_hqvdp.c
@@ -617,9 +617,9 @@ static void sti_hqvdp_init(struct sti_hqvdp *hqvdp)
 	/* Allocate memory for the VDP commands */
 	size = NB_VDP_CMD * sizeof(struct sti_hqvdp_cmd);
-	hqvdp->hqvdp_cmd = dma_alloc_writecombine(hqvdp->dev, size,
-					 &hqvdp->hqvdp_cmd_paddr,
+	hqvdp->hqvdp_cmd = dma_alloc_wc(hqvdp->dev, size,
+					&hqvdp->hqvdp_cmd_paddr,
 	if (!hqvdp->hqvdp_cmd) {
 		DRM_ERROR("Failed to allocate memory for VDP cmd\n");
 		return;
diff --git a/drivers/gpu/drm/tegra/gem.c b/drivers/gpu/drm/tegra/gem.c
index 33add93..3b0d8c3 100644
--- a/drivers/gpu/drm/tegra/gem.c
+++ b/drivers/gpu/drm/tegra/gem.c
@@ -175,8 +175,7 @@ static void tegra_bo_free(struct drm_device *drm, struct tegra_bo *bo)
 		sg_free_table(bo->sgt);
 		kfree(bo->sgt);
 	} else if (bo->vaddr) {
-		dma_free_writecombine(drm->dev, bo->gem.size, bo->vaddr,
-				      bo->paddr);
+		dma_free_wc(drm->dev, bo->gem.size, bo->vaddr, bo->paddr);
@@ -233,8 +232,8 @@ static int tegra_bo_alloc(struct drm_device *drm, struct tegra_bo *bo)
 	} else {
 		size_t size = bo->gem.size;
-		bo->vaddr = dma_alloc_writecombine(drm->dev, size, &bo->paddr,
-						   GFP_KERNEL | __GFP_NOWARN);
+		bo->vaddr = dma_alloc_wc(drm->dev, size, &bo->paddr,
 		if (!bo->vaddr) {
 			dev_err(drm->dev,
 				"failed to allocate buffer of size %zu\n",
@@ -472,8 +471,8 @@ int tegra_drm_mmap(struct file *file, struct vm_area_struct *vma)
 		vma->vm_pgoff = 0;
-		ret = dma_mmap_writecombine(gem->dev->dev, vma, bo->vaddr,
-					    bo->paddr, gem->size);
+		ret = dma_mmap_wc(gem->dev->dev, vma, bo->vaddr, bo->paddr,
+				  gem->size);
 		if (ret) {
 			return ret;
diff --git a/drivers/gpu/drm/vc4/vc4_bo.c b/drivers/gpu/drm/vc4/vc4_bo.c
index 22278bc..034ef2d 100644
--- a/drivers/gpu/drm/vc4/vc4_bo.c
+++ b/drivers/gpu/drm/vc4/vc4_bo.c
@@ -398,9 +398,8 @@ int vc4_mmap(struct file *filp, struct vm_area_struct *vma)
 	vma->vm_pgoff = 0;
-	ret = dma_mmap_writecombine(bo->base.base.dev->dev, vma,
-				    bo->base.vaddr, bo->base.paddr,
+	ret = dma_mmap_wc(bo->base.base.dev->dev, vma, bo->base.vaddr,
+			  bo->base.paddr, vma->vm_end - vma->vm_start);
 	if (ret)
diff --git a/drivers/gpu/host1x/cdma.c b/drivers/gpu/host1x/cdma.c
index 5a8c8d5..a18db4d 100644
--- a/drivers/gpu/host1x/cdma.c
+++ b/drivers/gpu/host1x/cdma.c
@@ -52,8 +52,8 @@ static void host1x_pushbuffer_destroy(struct push_buffer *pb)
 	struct host1x *host1x = cdma_to_host1x(cdma);
 	if (pb->phys != 0)
-		dma_free_writecombine(host1x->dev, pb->size_bytes + 4,
-				      pb->mapped, pb->phys);
+		dma_free_wc(host1x->dev, pb->size_bytes + 4, pb->mapped,
+			    pb->phys);
 	pb->mapped = NULL;
 	pb->phys = 0;
@@ -76,8 +76,8 @@ static int host1x_pushbuffer_init(struct push_buffer *pb)
 	pb->pos = 0;
 	/* allocate and map pushbuffer memory */
-	pb->mapped = dma_alloc_writecombine(host1x->dev, pb->size_bytes + 4,
-					    &pb->phys, GFP_KERNEL);
+	pb->mapped = dma_alloc_wc(host1x->dev, pb->size_bytes + 4, &pb->phys,
+				  GFP_KERNEL);
 	if (!pb->mapped)
 		goto fail;
diff --git a/drivers/gpu/host1x/job.c b/drivers/gpu/host1x/job.c
index 63bd63f..defa799 100644
--- a/drivers/gpu/host1x/job.c
+++ b/drivers/gpu/host1x/job.c
@@ -467,9 +467,8 @@ static inline int copy_gathers(struct host1x_job *job, struct device *dev)
 		size += g->words * sizeof(u32);
-	job->gather_copy_mapped = dma_alloc_writecombine(dev, size,
-							 &job->gather_copy,
-							 GFP_KERNEL);
+	job->gather_copy_mapped = dma_alloc_wc(dev, size, &job->gather_copy,
+					       GFP_KERNEL);
 	if (!job->gather_copy_mapped) {
 		job->gather_copy_mapped = NULL;
 		return -ENOMEM;
@@ -578,9 +577,8 @@ void host1x_job_unpin(struct host1x_job *job)
 	job->num_unpins = 0;
 	if (job->gather_copy_size)
-		dma_free_writecombine(job->channel->dev, job->gather_copy_size,
-				      job->gather_copy_mapped,
-				      job->gather_copy);
+		dma_free_wc(job->channel->dev, job->gather_copy_size,
+		            job->gather_copy_mapped, job->gather_copy);
 EXPORT_SYMBOL(host1x_job_unpin);
diff --git a/drivers/media/platform/coda/coda-bit.c b/drivers/media/platform/coda/coda-bit.c
index 7d28899..38aacc7 100644
--- a/drivers/media/platform/coda/coda-bit.c
+++ b/drivers/media/platform/coda/coda-bit.c
@@ -1455,9 +1455,9 @@ static int coda_alloc_bitstream_buffer(struct coda_ctx *ctx,
 		return 0;
 	ctx->bitstream.size = roundup_pow_of_two(q_data->sizeimage * 2);
-	ctx->bitstream.vaddr = dma_alloc_writecombine(
-			&ctx->dev->plat_dev->dev, ctx->bitstream.size,
-			&ctx->bitstream.paddr, GFP_KERNEL);
+	ctx->bitstream.vaddr = dma_alloc_wc(&ctx->dev->plat_dev->dev,
+					    ctx->bitstream.size,
+					    &ctx->bitstream.paddr, GFP_KERNEL);
 	if (!ctx->bitstream.vaddr) {
 		v4l2_err(&ctx->dev->v4l2_dev,
 			 "failed to allocate bitstream ringbuffer");
@@ -1474,8 +1474,8 @@ static void coda_free_bitstream_buffer(struct coda_ctx *ctx)
 	if (ctx->bitstream.vaddr == NULL)
 		return;
-	dma_free_writecombine(&ctx->dev->plat_dev->dev, ctx->bitstream.size,
-			      ctx->bitstream.vaddr, ctx->bitstream.paddr);
+	dma_free_wc(&ctx->dev->plat_dev->dev, ctx->bitstream.size,
+		    ctx->bitstream.vaddr, ctx->bitstream.paddr);
 	ctx->bitstream.vaddr = NULL;
 	kfifo_init(&ctx->bitstream_fifo, NULL, 0);
diff --git a/drivers/video/fbdev/acornfb.c b/drivers/video/fbdev/acornfb.c
index a305cae..fb75b7e 100644
--- a/drivers/video/fbdev/acornfb.c
+++ b/drivers/video/fbdev/acornfb.c
@@ -1040,8 +1040,8 @@ static int acornfb_probe(struct platform_device *dev)
 		 * for the framebuffer if we are not using
 		 * VRAM.
-		base = dma_alloc_writecombine(current_par.dev, size, &handle,
-					      GFP_KERNEL);
+		base = dma_alloc_wc(current_par.dev, size, &handle,
+				    GFP_KERNEL);
 		if (base == NULL) {
 			printk(KERN_ERR "acornfb: unable to allocate screen "
 			       "memory\n");
diff --git a/drivers/video/fbdev/amba-clcd-versatile.c b/drivers/video/fbdev/amba-clcd-versatile.c
index 7a8afcd..a8a22da 100644
--- a/drivers/video/fbdev/amba-clcd-versatile.c
+++ b/drivers/video/fbdev/amba-clcd-versatile.c
@@ -154,8 +154,8 @@ int versatile_clcd_setup_dma(struct clcd_fb *fb, unsigned long framesize)
 	dma_addr_t dma;
-	fb->fb.screen_base = dma_alloc_writecombine(&fb->dev->dev, framesize,
+	fb->fb.screen_base = dma_alloc_wc(&fb->dev->dev, framesize, &dma,
+					  GFP_KERNEL);
 		return -ENOMEM;
@@ -169,14 +169,12 @@ int versatile_clcd_setup_dma(struct clcd_fb *fb, unsigned long framesize)
 int versatile_clcd_mmap_dma(struct clcd_fb *fb, struct vm_area_struct *vma)
 void versatile_clcd_remove_dma(struct clcd_fb *fb)
diff --git a/drivers/video/fbdev/amba-clcd.c b/drivers/video/fbdev/amba-clcd.c
index 9362424..fe274b5 100644
--- a/drivers/video/fbdev/amba-clcd.c
+++ b/drivers/video/fbdev/amba-clcd.c
@@ -774,8 +774,8 @@ static int clcdfb_of_dma_setup(struct clcd_fb *fb)
 static int clcdfb_of_dma_mmap(struct clcd_fb *fb, struct vm_area_struct *vma)
-	return dma_mmap_writecombine(&fb->dev->dev, vma, fb->fb.screen_base,
-			fb->fb.fix.smem_start, fb->fb.fix.smem_len);
 static void clcdfb_of_dma_remove(struct clcd_fb *fb)
diff --git a/drivers/video/fbdev/atmel_lcdfb.c b/drivers/video/fbdev/atmel_lcdfb.c
index 19eb42b..56c60e6 100644
--- a/drivers/video/fbdev/atmel_lcdfb.c
+++ b/drivers/video/fbdev/atmel_lcdfb.c
@@ -414,8 +414,8 @@ static inline void atmel_lcdfb_free_video_memory(struct atmel_lcdfb_info *sinfo)
 	struct fb_info *info = sinfo->info;
-	dma_free_writecombine(info->device, info->fix.smem_len,
-				info->screen_base, info->fix.smem_start);
+	dma_free_wc(info->device, info->fix.smem_len, info->screen_base,
+		    info->fix.smem_start);
@@ -435,8 +435,9 @@ static int atmel_lcdfb_alloc_video_memory(struct atmel_lcdfb_info *sinfo)
 		    * ((var->bits_per_pixel + 7) / 8));
 	info->fix.smem_len = max(smem_len, sinfo->smem_len);
-	info->screen_base = dma_alloc_writecombine(info->device, info->fix.smem_len,
-					(dma_addr_t *)&info->fix.smem_start, GFP_KERNEL);
+	info->screen_base = dma_alloc_wc(info->device, info->fix.smem_len,
+					 (dma_addr_t *)&info->fix.smem_start,
+					 GFP_KERNEL);
 	if (!info->screen_base) {
 		return -ENOMEM;
diff --git a/drivers/video/fbdev/ep93xx-fb.c b/drivers/video/fbdev/ep93xx-fb.c
index 5b10810..75f0db2 100644
--- a/drivers/video/fbdev/ep93xx-fb.c
+++ b/drivers/video/fbdev/ep93xx-fb.c
@@ -316,9 +316,8 @@ static int ep93xxfb_mmap(struct fb_info *info, struct vm_area_struct *vma)
 	unsigned int offset = vma->vm_pgoff << PAGE_SHIFT;
 	if (offset < info->fix.smem_len) {
-		return dma_mmap_writecombine(info->dev, vma, info->screen_base,
-					     info->fix.smem_start,
-					     info->fix.smem_len);
+		return dma_mmap_wc(info->dev, vma, info->screen_base,
+				   info->fix.smem_start, info->fix.smem_len);
 	return -EINVAL;
@@ -428,8 +427,7 @@ static int ep93xxfb_alloc_videomem(struct fb_info *info)
 	/* Maximum 16bpp -> used memory is maximum x*y*2 bytes */
 	fb_size = EP93XXFB_MAX_XRES * EP93XXFB_MAX_YRES * 2;
-	virt_addr = dma_alloc_writecombine(info->dev, fb_size,
-					   &phys_addr, GFP_KERNEL);
+	virt_addr = dma_alloc_wc(info->dev, fb_size, &phys_addr, GFP_KERNEL);
 	if (!virt_addr)
 		return -ENOMEM;
diff --git a/drivers/video/fbdev/gbefb.c b/drivers/video/fbdev/gbefb.c
index b63d55f..1a242b1 100644
--- a/drivers/video/fbdev/gbefb.c
+++ b/drivers/video/fbdev/gbefb.c
@@ -1185,8 +1185,8 @@ static int gbefb_probe(struct platform_device *p_dev)
 	} else {
 		/* try to allocate memory with the classical allocator
 		 * this has high chance to fail on low memory machines */
-		gbe_mem = dma_alloc_writecombine(NULL, gbe_mem_size,
-						 &gbe_dma_addr, GFP_KERNEL);
+		gbe_mem = dma_alloc_wc(NULL, gbe_mem_size, &gbe_dma_addr,
+				       GFP_KERNEL);
 		if (!gbe_mem) {
 			printk(KERN_ERR "gbefb: couldn't allocate framebuffer memory\n");
 			ret = -ENOMEM;
@@ -1238,7 +1238,7 @@ static int gbefb_probe(struct platform_device *p_dev)
 out_gbe_unmap:
 	arch_phys_wc_del(par->wc_cookie);
 	if (gbe_dma_addr)
-		dma_free_writecombine(NULL, gbe_mem_size, gbe_mem, gbe_mem_phys);
+		dma_free_wc(NULL, gbe_mem_size, gbe_mem, gbe_mem_phys);
 out_tiles_free:
 	dma_free_coherent(NULL, GBE_TLB_SIZE * sizeof(uint16_t),
 			  (void *)gbe_tiles.cpu, gbe_tiles.dma);
@@ -1259,7 +1259,7 @@ static int gbefb_remove(struct platform_device* p_dev)
 	gbe_turn_off();
 	if (gbe_dma_addr)
 	release_mem_region(GBE_BASE, sizeof(struct sgi_gbe));
diff --git a/drivers/video/fbdev/imxfb.c b/drivers/video/fbdev/imxfb.c
index bb2f1e8..76b6a77 100644
--- a/drivers/video/fbdev/imxfb.c
+++ b/drivers/video/fbdev/imxfb.c
@@ -937,8 +937,8 @@ static int imxfb_probe(struct platform_device *pdev)
 	fbi->map_size = PAGE_ALIGN(info->fix.smem_len);
-	info->screen_base = dma_alloc_writecombine(&pdev->dev, fbi->map_size,
-						   &fbi->map_dma, GFP_KERNEL);
+	info->screen_base = dma_alloc_wc(&pdev->dev, fbi->map_size,
+					 &fbi->map_dma, GFP_KERNEL);
 		dev_err(&pdev->dev, "Failed to allocate video RAM: %d\n", ret);
@@ -1005,8 +1005,8 @@ failed_cmap:
 	if (pdata && pdata->exit)
 		pdata->exit(fbi->pdev);
 failed_platform_init:
-	dma_free_writecombine(&pdev->dev, fbi->map_size, info->screen_base,
-			      fbi->map_dma);
+	dma_free_wc(&pdev->dev, fbi->map_size, info->screen_base,
+		    fbi->map_dma);
 failed_map:
 	iounmap(fbi->regs);
 failed_ioremap:
@@ -1041,8 +1041,8 @@ static int imxfb_remove(struct platform_device *pdev)
 	kfree(info->pseudo_palette);
 	framebuffer_release(info);
-			      fbi->map_dma);
+		    fbi->map_dma);
 	iounmap(fbi->regs);
 	release_mem_region(res->start, resource_size(res));
diff --git a/drivers/video/fbdev/mx3fb.c b/drivers/video/fbdev/mx3fb.c
index 7947634..f91b1db 100644
--- a/drivers/video/fbdev/mx3fb.c
+++ b/drivers/video/fbdev/mx3fb.c
@@ -1336,9 +1336,8 @@ static int mx3fb_map_video_memory(struct fb_info *fbi, unsigned int mem_len,
 	int retval = 0;
 	dma_addr_t addr;
-	fbi->screen_base = dma_alloc_writecombine(fbi->device,
-						  mem_len,
-						  &addr, GFP_DMA | GFP_KERNEL);
+	fbi->screen_base = dma_alloc_wc(fbi->device, mem_len, &addr,
+					GFP_DMA | GFP_KERNEL);
 	if (!fbi->screen_base) {
 		dev_err(fbi->device, "Cannot allocate %u bytes framebuffer memory\n",
@@ -1378,8 +1377,8 @@ err0:
 static int mx3fb_unmap_video_memory(struct fb_info *fbi)
-	dma_free_writecombine(fbi->device, fbi->fix.smem_len,
-			      fbi->screen_base, fbi->fix.smem_start);
+	dma_free_wc(fbi->device, fbi->fix.smem_len, fbi->screen_base,
+		    fbi->fix.smem_start);
 	fbi->screen_base = NULL;
 	mutex_lock(&fbi->mm_lock);
diff --git a/drivers/video/fbdev/nuc900fb.c b/drivers/video/fbdev/nuc900fb.c
index 389fa2c..6680eda 100644
--- a/drivers/video/fbdev/nuc900fb.c
+++ b/drivers/video/fbdev/nuc900fb.c
@@ -396,8 +396,8 @@ static int nuc900fb_map_video_memory(struct fb_info *info)
 	dev_dbg(fbi->dev, "nuc900fb_map_video_memory(fbi=%p) map_size %lu\n",
 		fbi, map_size);
-	info->screen_base = dma_alloc_writecombine(fbi->dev, map_size,
-							&map_dma, GFP_KERNEL);
+	info->screen_base = dma_alloc_wc(fbi->dev, map_size, &map_dma,
+					 GFP_KERNEL);
 		return -ENOMEM;
@@ -411,8 +411,8 @@ static int nuc900fb_map_video_memory(struct fb_info *info)
 static inline void nuc900fb_unmap_video_memory(struct fb_info *info)
 	struct nuc900fb_info *fbi = info->par;
-	dma_free_writecombine(fbi->dev, PAGE_ALIGN(info->fix.smem_len),
+	dma_free_wc(fbi->dev, PAGE_ALIGN(info->fix.smem_len),
+		    info->screen_base, info->fix.smem_start);
 static irqreturn_t nuc900fb_irqhandler(int irq, void *dev_id)
diff --git a/drivers/video/fbdev/omap/lcdc.c b/drivers/video/fbdev/omap/lcdc.c
index 6efa259..e3d9b9e 100644
--- a/drivers/video/fbdev/omap/lcdc.c
+++ b/drivers/video/fbdev/omap/lcdc.c
@@ -612,8 +612,8 @@ static void lcdc_dma_handler(u16 status, void *data)
 static int alloc_palette_ram(void)
-	lcdc.palette_virt = dma_alloc_writecombine(lcdc.fbdev->dev,
-		MAX_PALETTE_SIZE, &lcdc.palette_phys, GFP_KERNEL);
+	lcdc.palette_virt = dma_alloc_wc(lcdc.fbdev->dev, MAX_PALETTE_SIZE,
+					 &lcdc.palette_phys, GFP_KERNEL);
 	if (lcdc.palette_virt == NULL) {
 		dev_err(lcdc.fbdev->dev, "failed to alloc palette memory\n");
 		return -ENOMEM;
@@ -625,8 +625,8 @@ static int alloc_palette_ram(void)
 static void free_palette_ram(void)
-	dma_free_writecombine(lcdc.fbdev->dev, MAX_PALETTE_SIZE,
-			lcdc.palette_virt, lcdc.palette_phys);
+	dma_free_wc(lcdc.fbdev->dev, MAX_PALETTE_SIZE, lcdc.palette_virt,
+		    lcdc.palette_phys);
 static int alloc_fbmem(struct omapfb_mem_region *region)
@@ -642,8 +642,8 @@ static int alloc_fbmem(struct omapfb_mem_region *region)
 	if (region->size > frame_size)
 		frame_size = region->size;
 	lcdc.vram_size = frame_size;
-	lcdc.vram_virt = dma_alloc_writecombine(lcdc.fbdev->dev,
-			lcdc.vram_size, &lcdc.vram_phys, GFP_KERNEL);
+	lcdc.vram_virt = dma_alloc_wc(lcdc.fbdev->dev, lcdc.vram_size,
+				      &lcdc.vram_phys, GFP_KERNEL);
 	if (lcdc.vram_virt == NULL) {
 		dev_err(lcdc.fbdev->dev, "unable to allocate FB DMA memory\n");
 		return -ENOMEM;
@@ -660,8 +660,8 @@ static int alloc_fbmem(struct omapfb_mem_region *region)
 static void free_fbmem(void)
-	dma_free_writecombine(lcdc.fbdev->dev, lcdc.vram_size,
-			      lcdc.vram_virt, lcdc.vram_phys);
+	dma_free_wc(lcdc.fbdev->dev, lcdc.vram_size, lcdc.vram_virt,
+		    lcdc.vram_phys);
 static int setup_fbmem(struct omapfb_mem_desc *req_md)
diff --git a/drivers/video/fbdev/pxa168fb.c b/drivers/video/fbdev/pxa168fb.c
index efb57c0..def3a50 100644
--- a/drivers/video/fbdev/pxa168fb.c
+++ b/drivers/video/fbdev/pxa168fb.c
@@ -680,8 +680,8 @@ static int pxa168fb_probe(struct platform_device *pdev)
 	info->fix.smem_len = PAGE_ALIGN(DEFAULT_FB_SIZE);
-	info->screen_base = dma_alloc_writecombine(fbi->dev, info->fix.smem_len,
-						&fbi->fb_start_dma, GFP_KERNEL);
+	info->screen_base = dma_alloc_wc(fbi->dev, info->fix.smem_len,
+					 &fbi->fb_start_dma, GFP_KERNEL);
 	if (info->screen_base == NULL) {
 		ret = -ENOMEM;
 		goto failed_free_info;
@@ -804,8 +804,8 @@ static int pxa168fb_remove(struct platform_device *pdev)
 	irq = platform_get_irq(pdev, 0);
 	clk_disable(fbi->clk);
diff --git a/drivers/video/fbdev/pxafb.c b/drivers/video/fbdev/pxafb.c
index 33b2bb3..2c0487f 100644
--- a/drivers/video/fbdev/pxafb.c
+++ b/drivers/video/fbdev/pxafb.c
@@ -2446,8 +2446,8 @@ static int pxafb_remove(struct platform_device *dev)
 	free_pages_exact(fbi->video_mem, fbi->video_mem_size);
-	dma_free_writecombine(&dev->dev, fbi->dma_buff_size,
-			fbi->dma_buff, fbi->dma_buff_phys);
+	dma_free_wc(&dev->dev, fbi->dma_buff_size, fbi->dma_buff,
+		    fbi->dma_buff_phys);
 	iounmap(fbi->mmio_base);
diff --git a/drivers/video/fbdev/s3c-fb.c b/drivers/video/fbdev/s3c-fb.c
index f72dd12..5f4f696 100644
--- a/drivers/video/fbdev/s3c-fb.c
+++ b/drivers/video/fbdev/s3c-fb.c
@@ -1105,8 +1105,7 @@ static int s3c_fb_alloc_memory(struct s3c_fb *sfb, struct s3c_fb_win *win)
 	dev_dbg(sfb->dev, "want %u bytes for window\n", size);
-	fbi->screen_base = dma_alloc_writecombine(sfb->dev, size,
+	fbi->screen_base = dma_alloc_wc(sfb->dev, size, &map_dma, GFP_KERNEL);
 		return -ENOMEM;
@@ -1131,8 +1130,8 @@ static void s3c_fb_free_memory(struct s3c_fb *sfb, struct s3c_fb_win *win)
 	struct fb_info *fbi = win->fbinfo;
 	if (fbi->screen_base)
-		dma_free_writecombine(sfb->dev, PAGE_ALIGN(fbi->fix.smem_len),
+		dma_free_wc(sfb->dev, PAGE_ALIGN(fbi->fix.smem_len),
+		            fbi->screen_base, fbi->fix.smem_start);
diff --git a/drivers/video/fbdev/s3c2410fb.c b/drivers/video/fbdev/s3c2410fb.c
index d6704ad..0dd86be 100644
--- a/drivers/video/fbdev/s3c2410fb.c
+++ b/drivers/video/fbdev/s3c2410fb.c
@@ -645,8 +645,8 @@ static int s3c2410fb_map_video_memory(struct fb_info *info)
 	dprintk("map_video_memory(fbi=%p) map_size %u\n", fbi, map_size);
+					 GFP_KERNEL);
 	if (info->screen_base) {
 		/* prevent initial garbage on screen */
@@ -667,8 +667,8 @@ static inline void s3c2410fb_unmap_video_memory(struct fb_info *info)
 	struct s3c2410fb_info *fbi = info->par;
 static inline void modify_gpio(void __iomem *reg,
diff --git a/drivers/video/fbdev/sa1100fb.c b/drivers/video/fbdev/sa1100fb.c
index dcf774c..fc2aaa5 100644
--- a/drivers/video/fbdev/sa1100fb.c
+++ b/drivers/video/fbdev/sa1100fb.c
@@ -567,8 +567,8 @@ static int sa1100fb_mmap(struct fb_info *info,
 	if (off < info->fix.smem_len) {
 		vma->vm_pgoff += 1; /* skip over the palette */
-		return dma_mmap_writecombine(fbi->dev, vma, fbi->map_cpu,
-					     fbi->map_dma, fbi->map_size);
+		return dma_mmap_wc(fbi->dev, vma, fbi->map_cpu, fbi->map_dma,
+				   fbi->map_size);
 	vma->vm_page_prot = pgprot_noncached(vma->vm_page_prot);
@@ -1099,8 +1099,8 @@ static int sa1100fb_map_video_memory(struct sa1100fb_info *fbi)
 	 * of the framebuffer.
 	fbi->map_size = PAGE_ALIGN(fbi->fb.fix.smem_len + PAGE_SIZE);
-	fbi->map_cpu = dma_alloc_writecombine(fbi->dev, fbi->map_size,
+	fbi->map_cpu = dma_alloc_wc(fbi->dev, fbi->map_size, &fbi->map_dma,
+				    GFP_KERNEL);
 	if (fbi->map_cpu) {
 		fbi->fb.screen_base = fbi->map_cpu + PAGE_SIZE;
diff --git a/include/linux/dma-mapping.h b/include/linux/dma-mapping.h
index 75857cd..471e064 100644
--- a/include/linux/dma-mapping.h
+++ b/include/linux/dma-mapping.h
@@ -641,31 +641,40 @@ static inline void dmam_release_declared_memory(struct device *dev)
 #endif /* CONFIG_HAVE_GENERIC_DMA_COHERENT */
-static inline void *dma_alloc_writecombine(struct device *dev, size_t size,
-					   dma_addr_t *dma_addr, gfp_t gfp)
+static inline void *dma_alloc_wc(struct device *dev, size_t size,
+				 dma_addr_t *dma_addr, gfp_t gfp)
 	DEFINE_DMA_ATTRS(attrs);
 	dma_set_attr(DMA_ATTR_WRITE_COMBINE, &attrs);
 	return dma_alloc_attrs(dev, size, dma_addr, gfp, &attrs);
+#ifndef dma_alloc_writecombine
+#define dma_alloc_writecombine dma_alloc_wc
+#endif
-static inline void dma_free_writecombine(struct device *dev, size_t size,
-					 void *cpu_addr, dma_addr_t dma_addr)
+static inline void dma_free_wc(struct device *dev, size_t size,
+			       void *cpu_addr, dma_addr_t dma_addr)
 	return dma_free_attrs(dev, size, cpu_addr, dma_addr, &attrs);
+#ifndef dma_free_writecombine
+#define dma_free_writecombine dma_free_wc
+#endif
-static inline int dma_mmap_writecombine(struct device *dev,
-					struct vm_area_struct *vma,
-					void *cpu_addr, dma_addr_t dma_addr,
-					size_t size)
+static inline int dma_mmap_wc(struct device *dev,
+			      struct vm_area_struct *vma,
+			      void *cpu_addr, dma_addr_t dma_addr,
+			      size_t size)
 	return dma_mmap_attrs(dev, vma, cpu_addr, dma_addr, size, &attrs);
+#ifndef dma_mmap_writecombine
+#define dma_mmap_writecombine dma_mmap_wc
+#endif
 #ifdef CONFIG_NEED_DMA_MAP_STATE
 #define DEFINE_DMA_UNMAP_ADDR(ADDR_NAME)        dma_addr_t ADDR_NAME
diff --git a/sound/arm/pxa2xx-pcm-lib.c b/sound/arm/pxa2xx-pcm-lib.c
index e9b98af..e8da3b8 100644
--- a/sound/arm/pxa2xx-pcm-lib.c
+++ b/sound/arm/pxa2xx-pcm-lib.c
@@ -141,10 +141,8 @@ int pxa2xx_pcm_mmap(struct snd_pcm_substream *substream,
 	struct snd_pcm_runtime *runtime = substream->runtime;
-	return dma_mmap_writecombine(substream->pcm->card->dev, vma,
-				     runtime->dma_area,
-				     runtime->dma_addr,
-				     runtime->dma_bytes);
+	return dma_mmap_wc(substream->pcm->card->dev, vma, runtime->dma_area,
+			   runtime->dma_addr, runtime->dma_bytes);
 EXPORT_SYMBOL(pxa2xx_pcm_mmap);
@@ -156,8 +154,7 @@ int pxa2xx_pcm_preallocate_dma_buffer(struct snd_pcm *pcm, int stream)
 	buf->dev.type = SNDRV_DMA_TYPE_DEV;
 	buf->dev.dev = pcm->card->dev;
 	buf->private_data = NULL;
-	buf->area = dma_alloc_writecombine(pcm->card->dev, size,
-					   &buf->addr, GFP_KERNEL);
+	buf->area = dma_alloc_wc(pcm->card->dev, size, &buf->addr, GFP_KERNEL);
 	if (!buf->area)
 		return -ENOMEM;
 	buf->bytes = size;
@@ -178,8 +175,7 @@ void pxa2xx_pcm_free_dma_buffers(struct snd_pcm *pcm)
 		buf = &substream->dma_buffer;
 		if (!buf->area)
 			continue;
-		dma_free_writecombine(pcm->card->dev, buf->bytes,
-				      buf->area, buf->addr);
+		dma_free_wc(pcm->card->dev, buf->bytes, buf->area, buf->addr);
 		buf->area = NULL;
diff --git a/sound/soc/fsl/imx-pcm-fiq.c b/sound/soc/fsl/imx-pcm-fiq.c
index 49d7513..e63cd5e 100644
--- a/sound/soc/fsl/imx-pcm-fiq.c
+++ b/sound/soc/fsl/imx-pcm-fiq.c
@@ -217,8 +217,8 @@ static int snd_imx_pcm_mmap(struct snd_pcm_substream *substream,
 	int ret;
-	ret = dma_mmap_writecombine(substream->pcm->card->dev, vma,
-		runtime->dma_area, runtime->dma_addr, runtime->dma_bytes);
+	ret = dma_mmap_wc(substream->pcm->card->dev, vma, runtime->dma_area,
 	pr_debug("%s: ret: %d %p %pad 0x%08x\n", __func__, ret,
 			runtime->dma_area,
@@ -247,8 +247,7 @@ static int imx_pcm_preallocate_dma_buffer(struct snd_pcm *pcm, int stream)
 	if (!buf->area)
 		return -ENOMEM;
 	buf->bytes = size;
@@ -330,8 +329,7 @@ static void imx_pcm_free(struct snd_pcm *pcm)
 		if (!buf->area)
 			continue;
 		buf->area = NULL;
diff --git a/sound/soc/nuc900/nuc900-pcm.c b/sound/soc/nuc900/nuc900-pcm.c
index e093261..2cca055 100644
--- a/sound/soc/nuc900/nuc900-pcm.c
+++ b/sound/soc/nuc900/nuc900-pcm.c
@@ -267,10 +267,8 @@ static int nuc900_dma_mmap(struct snd_pcm_substream *substream,
 static struct snd_pcm_ops nuc900_dma_ops = {
diff --git a/sound/soc/omap/omap-pcm.c b/sound/soc/omap/omap-pcm.c
index 6bb623a..99381a2 100644
--- a/sound/soc/omap/omap-pcm.c
+++ b/sound/soc/omap/omap-pcm.c
@@ -156,10 +156,8 @@ static int omap_pcm_mmap(struct snd_pcm_substream *substream,
 static struct snd_pcm_ops omap_pcm_ops = {
@@ -183,8 +181,7 @@ static int omap_pcm_preallocate_dma_buffer(struct snd_pcm *pcm,
 	if (!buf->area)
 		return -ENOMEM;
@@ -207,8 +204,7 @@ static void omap_pcm_free_dma_buffers(struct snd_pcm *pcm)
 		if (!buf->area)
 			continue;
 		buf->area = NULL;
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
