dm thin: Remove return statement from void function
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
Return statement at the end of a void function is useless.
The Coccinelle semantic patch used to make this change is as follows:
identifier f;
expression e;
void f(...) {
- return
  e;
Signed-off-by: Amitoj Kaur Chawla
Signed-off-by: Mike Snitzer
 drivers/md/dm-thin.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/md/dm-thin.c b/drivers/md/dm-thin.c
index 92237b6..04e7f3b 100644
--- a/drivers/md/dm-thin.c
+++ b/drivers/md/dm-thin.c
@@ -632,7 +632,7 @@ static void error_retry_list(struct pool *pool)
 	int error = get_pool_io_error_code(pool);
-	return error_retry_list_with_code(pool, error);
+	error_retry_list_with_code(pool, error);
