dm snapshot: remove unnecessary NULL checks before vfree() calls
Author: Markus Elfring <elfring@users.sourceforge.net>
The vfree() function performs input parameter validation.
Thus the NULL pointer test around vfree() calls is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Mike Snitzer
drivers/md/dm-snap-persistent.c | 14 ++++----------
1 file changed, 4 insertions(+), 10 deletions(-)
diff --git a/drivers/md/dm-snap-persistent.c b/drivers/md/dm-snap-persistent.c
index d6e8817..808b841 100644
--- a/drivers/md/dm-snap-persistent.c
+++ b/drivers/md/dm-snap-persistent.c
@@ -200,16 +200,11 @@ err_area:
static void free_area(struct pstore *ps)
- if (ps->area)
- vfree(ps->area);
+ vfree(ps->area);
ps->area = NULL;
- if (ps->zero_area)
- vfree(ps->zero_area);
+ vfree(ps->zero_area);
ps->zero_area = NULL;
- if (ps->header_area)
- vfree(ps->header_area);
+ vfree(ps->header_area);
ps->header_area = NULL;
@@ -605,8 +600,7 @@ static void persistent_dtr(struct dm_exception_store *store)
free_area(ps);
/* Allocated in persistent_read_metadata */
- if (ps->callbacks)
- vfree(ps->callbacks);
+ vfree(ps->callbacks);
kfree(ps);
- if (ps->area)
- vfree(ps->area);
+ vfree(ps->area);
ps->area = NULL;
free_area(ps);
kfree(ps);
