dm mpath: fix check for null mpio in end_io fn
Author: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
The mpio dereference should be moved below the BUG_ON NULL test
in multipath_end_io().
spatch with a semantic match was used to found this.
(http://coccinelle.lip6.fr/)
Signed-off-by: Wei Yongjun
Signed-off-by: Alasdair G Kergon
drivers/md/dm-mpath.c | 3 ++-
1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/md/dm-mpath.c b/drivers/md/dm-mpath.c
index d778563..573bd04 100644
--- a/drivers/md/dm-mpath.c
+++ b/drivers/md/dm-mpath.c
@@ -1309,13 +1309,14 @@ static int multipath_end_io(struct dm_target *ti, struct request *clone,
struct multipath *m = ti->private;
struct dm_mpath_io *mpio = map_context->ptr;
- struct pgpath *pgpath = mpio->pgpath;
+ struct pgpath *pgpath;
struct path_selector *ps;
int r;
BUG_ON(!mpio);
r = do_end_io(m, clone, error, mpio);
+ pgpath = mpio->pgpath;
if (pgpath) {
ps = &pgpath->pg->ps;
if (ps->type->end_io) |
int r;
BUG_ON(!mpio);
if (pgpath) {
