cxl: Remove use of macro DEFINE_PCI_DEVICE_TABLE
Author: Vaishali Thakkar <vthakkar1994@gmail.com>
Macro DEFINE_PCI_DEVICE_TABLE is deprecated. So, here use
struct pci_device_id instead of DEFINE_PCI_DEVICE_TABLE with
the goal of getting rid of this macro completely.
The Coccinelle semantic patch that performs this transformation
is as follows:
identifier a;
declarer name DEFINE_PCI_DEVICE_TABLE;
initializer i;
- DEFINE_PCI_DEVICE_TABLE(a)
+ const struct pci_device_id a[]
= i;
Signed-off-by: Vaishali Thakkar
Acked-by: Michael Neuling
Acked-by: Ian Munsie
Signed-off-by: Michael Ellerman
 drivers/misc/cxl/pci.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/misc/cxl/pci.c b/drivers/misc/cxl/pci.c
index 03ddb2d..273374c 100644
--- a/drivers/misc/cxl/pci.c
+++ b/drivers/misc/cxl/pci.c
@@ -134,7 +134,7 @@ u8 cxl_afu_cr_read8(struct cxl_afu *afu, int cr, u64 off)
 	return (val >> ((off & 0x3) * 8)) & 0xff;
-static DEFINE_PCI_DEVICE_TABLE(cxl_pci_tbl) = {
+static const struct pci_device_id cxl_pci_tbl[] = {
 	{ PCI_DEVICE(PCI_VENDOR_ID_IBM, 0x0477), },
 	{ PCI_DEVICE(PCI_VENDOR_ID_IBM, 0x044b), },
 	{ PCI_DEVICE(PCI_VENDOR_ID_IBM, 0x04cf), },
BtrLinux
Privacy Overview
