ctcm: fix error return code
Author: Peter Senna Tschudin <peter.senna@gmail.com>
Convert a nonnegative error return code to a negative one, as returned
elsewhere in the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
if@p1 (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret@p1 = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Peter Senna Tschudin
Signed-off-by: Ursula Braun
Signed-off-by: Frank Blaschka
Signed-off-by: David S. Miller
 drivers/s390/net/ctcm_main.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/s390/net/ctcm_main.c b/drivers/s390/net/ctcm_main.c
index 5227e57..98ea9cc 100644
--- a/drivers/s390/net/ctcm_main.c
+++ b/drivers/s390/net/ctcm_main.c
@@ -1454,7 +1454,7 @@ static int add_channel(struct ccw_device *cdev, enum ctcm_channel_types type,
 				ch_fsm_len, GFP_KERNEL);
 	if (ch->fsm == NULL)
-				goto free_return;
+				goto nomem_return;
 	fsm_newstate(ch->fsm, CTC_STATE_IDLE);
BtrLinux
Privacy Overview
