crypto: Use ERR_CAST
Use ERR_CAST(x) rather than ERR_PTR(PTR_ERR(x)). The former makes more
clear what is the purpose of the operation, which otherwise looks like a
no-op.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
type T;
T x;
identifier f;
T f (...) { <+...
- ERR_PTR(PTR_ERR(x))
+ x
expression x;
+ ERR_CAST(x)
Signed-off-by: Julia Lawall
Signed-off-by: Herbert Xu
crypto/authenc.c | 2 +-
crypto/ctr.c | 2 +-
crypto/xts.c | 2 +-
3 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/crypto/authenc.c b/crypto/authenc.c
index b9884ee..a5a22cf 100644
--- a/crypto/authenc.c
+++ b/crypto/authenc.c
@@ -616,7 +616,7 @@ static struct crypto_instance *crypto_authenc_alloc(struct rtattr **tb)
auth = ahash_attr_alg(tb[1], CRYPTO_ALG_TYPE_HASH,
CRYPTO_ALG_TYPE_AHASH_MASK);
if (IS_ERR(auth))
- return ERR_PTR(PTR_ERR(auth));
+ return ERR_CAST(auth);
auth_base = &auth->base;
diff --git a/crypto/ctr.c b/crypto/ctr.c
index 6c3bfab..4ca7222 100644
--- a/crypto/ctr.c
+++ b/crypto/ctr.c
@@ -185,7 +185,7 @@ static struct crypto_instance *crypto_ctr_alloc(struct rtattr **tb)
alg = crypto_attr_alg(tb[1], CRYPTO_ALG_TYPE_CIPHER,
CRYPTO_ALG_TYPE_MASK);
if (IS_ERR(alg))
- return ERR_PTR(PTR_ERR(alg));
+ return ERR_CAST(alg);
/* Block size must be >= 4 bytes. */
err = -EINVAL;
diff --git a/crypto/xts.c b/crypto/xts.c
index d87b0f3..555ecaa 100644
--- a/crypto/xts.c
+++ b/crypto/xts.c
@@ -224,7 +224,7 @@ static struct crypto_instance *alloc(struct rtattr **tb)
alg = crypto_get_attr_alg(tb, CRYPTO_ALG_TYPE_CIPHER,
if (IS_ERR(alg))
inst = crypto_alloc_instance("xts", alg);
if (IS_ERR(inst)) |
crypto/ctr.c | 2 +-
crypto/xts.c | 2 +-
if (IS_ERR(auth))
--- a/crypto/ctr.c
+++ b/crypto/ctr.c
if (IS_ERR(alg))
err = -EINVAL;
--- a/crypto/xts.c
+++ b/crypto/xts.c
if (IS_ERR(alg))
if (IS_ERR(inst))
