crypto: qat – fix simple_return.cocci warnings
Author: Wu Fengguang <fengguang.wu@intel.com>
drivers/crypto/qat/qat_common/adf_sriov.c:258:1-4: WARNING: end returns can be simpified and declaration on line 212 can be dropped
 Simplify a trivial if-return sequence.  Possibly combine with a
 preceding function call.
Generated by: scripts/coccinelle/misc/simple_return.cocci
CC: Tadeusz Struk
Signed-off-by: Fengguang Wu
Signed-off-by: Herbert Xu
 drivers/crypto/qat/qat_common/adf_sriov.c | 8 ++------
 1 file changed, 2 insertions(+), 6 deletions(-)
diff --git a/drivers/crypto/qat/qat_common/adf_sriov.c b/drivers/crypto/qat/qat_common/adf_sriov.c
index a766fb5..069b9ea 100644
--- a/drivers/crypto/qat/qat_common/adf_sriov.c
+++ b/drivers/crypto/qat/qat_common/adf_sriov.c
@@ -209,7 +209,7 @@ static int adf_enable_sriov(struct adf_accel_dev *accel_dev)
 			&GET_BARS(accel_dev)[hw_data->get_misc_bar_id(hw_data)];
 	void __iomem *pmisc_addr = pmisc->virt_addr;
 	struct adf_accel_vf_info *vf_info;
-	int i, ret;
+	int i;
 	u32 reg;
 	/* Workqueue for PF2VF responses */
@@ -255,11 +255,7 @@ static int adf_enable_sriov(struct adf_accel_dev *accel_dev)
 	 * order for all the hardware resources (i.e. bundles) to be usable.
 	 * When SR-IOV is enabled, each of the VFs will own one bundle.
-	ret = pci_enable_sriov(pdev, totalvfs);
-	if (ret)
-		return ret;
-	return 0;
+	return pci_enable_sriov(pdev, totalvfs);
BtrLinux
Privacy Overview
