crypto: crct10dif – Use PTR_RET
Author: Herbert Xu <herbert@gondor.apana.org.au>
lib/crc-t10dif.c:42:1-3: WARNING: PTR_RET can be used
 Use PTR_RET rather than if(IS_ERR(...)) + PTR_ERR
Generated by: coccinelle/api/ptr_ret.cocci
Reported-by: Fengguang Wu
Signed-off-by: Herbert Xu
 lib/crc-t10dif.c | 4 +---
 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/lib/crc-t10dif.c b/lib/crc-t10dif.c
index 0cb6463..fe3428c 100644
--- a/lib/crc-t10dif.c
+++ b/lib/crc-t10dif.c
@@ -39,9 +39,7 @@ EXPORT_SYMBOL(crc_t10dif);
 static int __init crc_t10dif_mod_init(void)
 	crct10dif_tfm = crypto_alloc_shash("crct10dif", 0, 0);
-	if (IS_ERR(crct10dif_tfm))
-		return PTR_ERR(crct10dif_tfm);
-	return 0;
+	return PTR_RET(crct10dif_tfm);
 static void __exit crc_t10dif_mod_fini(void)
BtrLinux
Privacy Overview
