crypto: caam – Introduce the use of the managed version of kzalloc
Author: Himangi Saraogi <himangi774@gmail.com>
This patch moves data allocated using kzalloc to managed data allocated
using devm_kzalloc and cleans now unnecessary kfrees in probe and remove
functions.  Also, linux/device.h is added to make sure the devm_*()
routine declarations are unambiguously available. Earlier, in the probe
function ctrlpriv was leaked on the failure of ctrl = of_iomap(nprop, 0);
as well as on the failure of ctrlpriv->jrpdev = kzalloc(...); . These
two bugs have been fixed by the patch.
The following Coccinelle semantic patch was used for making the change:
identifier p, probefn, removefn;
struct platform_driver p = {
  .probe = probefn,
  .remove = removefn,
@prb@
identifier platform.probefn, pdev;
expression e, e1, e2;
probefn(struct platform_device *pdev, ...) {
- e = kzalloc(e1, e2)
+ e = devm_kzalloc(&pdev->dev, e1, e2)
?-kfree(e);
@rem depends on prb@
identifier platform.removefn;
expression e;
removefn(...) {
- kfree(e);
Signed-off-by: Himangi Saraogi
Acked-by: Julia Lawall
Reviewed-by: Marek Vasut
Signed-off-by: Herbert Xu
 drivers/crypto/caam/ctrl.c | 12 ++++++------
 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/drivers/crypto/caam/ctrl.c b/drivers/crypto/caam/ctrl.c
index 1c38f86..34ffc35 100644
--- a/drivers/crypto/caam/ctrl.c
+++ b/drivers/crypto/caam/ctrl.c
@@ -5,6 +5,7 @@
  * Copyright 2008-2012 Freescale Semiconductor, Inc.
+#include <linux/device.h>
 #include <linux/of_address.h>
 #include <linux/of_irq.h>
@@ -295,9 +296,6 @@ static int caam_remove(struct platform_device *pdev)
 	/* Unmap controller region */
 	iounmap(&topregs->ctrl);
-	kfree(ctrlpriv->jrpdev);
-	kfree(ctrlpriv);
 	return ret;
@@ -382,7 +380,8 @@ static int caam_probe(struct platform_device *pdev)
 #endif
 	u64 cha_vid;
-	ctrlpriv = kzalloc(sizeof(struct caam_drv_private), GFP_KERNEL);
+	ctrlpriv = devm_kzalloc(&pdev->dev, sizeof(struct caam_drv_private),
+				GFP_KERNEL);
 	if (!ctrlpriv)
 		return -ENOMEM;
@@ -432,8 +431,9 @@ static int caam_probe(struct platform_device *pdev)
 		    of_device_is_compatible(np, "fsl,sec4.0-job-ring"))
 			rspec++;
-	ctrlpriv->jrpdev = kzalloc(sizeof(struct platform_device *) * rspec,
-								GFP_KERNEL);
+	ctrlpriv->jrpdev = devm_kzalloc(&pdev->dev,
+					sizeof(struct platform_device *) * rspec,
+					GFP_KERNEL);
 	if (ctrlpriv->jrpdev == NULL) {
 		return -ENOMEM;
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
