crypto: caam – introduce missing kfree
Error handling code following a kmalloc should free the allocated data.
The semantic match that finds the problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@r exists@
local idexpression x;
statement S;
expression E;
identifier f,f1,l;
position p1,p2;
expression *ptr != NULL;
x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...);
if (x == NULL) S
<... when != x
     when != if (...) { <+...x...+> }
x->f1 = E
 (x->f1 == NULL || ...)
 f(...,x->f1,...)
 return \(0\|<+...x...+>\|ptr\);
 return@p2 ...;
@script:python@
p1 << r.p1;
p2 << r.p2;
print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line)
Signed-off-by: Julia Lawall
Acked-by: Kim Phillips
Signed-off-by: Herbert Xu
 drivers/crypto/caam/caamalg.c | 1 +
 1 file changed, 1 insertion(+)
diff --git a/drivers/crypto/caam/caamalg.c b/drivers/crypto/caam/caamalg.c
index dce44b2..20e1215 100644
--- a/drivers/crypto/caam/caamalg.c
+++ b/drivers/crypto/caam/caamalg.c
@@ -1120,6 +1120,7 @@ static int __init caam_algapi_init(void)
 	if (err < 0 && i == 0) {
 		dev_err(ctrldev, "algapi error in job ring registration: %d\n",
 			err);
+		kfree(jrdev);
 		return err;
BtrLinux
Privacy Overview
