crypto: bfin_crc – Simplify use of devm_ioremap_resource
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
Remove unneeded error handling on the result of a call to
platform_get_resource when the value is passed to
devm_ioremap_resource.
The Coccinelle semantic patch that makes this change is as follows:
expression pdev,res,n,e,e1;
expression ret != 0;
identifier l;
- res = platform_get_resource(pdev, IORESOURCE_MEM, n);
  ... when != res
- if (res == NULL) { ... \(goto l;\|return ret;\) }
  ... when != res
+ res = platform_get_resource(pdev, IORESOURCE_MEM, n);
  e = devm_ioremap_resource(e1, res);
Signed-off-by: Amitoj Kaur Chawla
Signed-off-by: Herbert Xu
 drivers/crypto/bfin_crc.c | 5 -----
 1 file changed, 5 deletions(-)
diff --git a/drivers/crypto/bfin_crc.c b/drivers/crypto/bfin_crc.c
index 95b7396..10db7df 100644
--- a/drivers/crypto/bfin_crc.c
+++ b/drivers/crypto/bfin_crc.c
@@ -588,11 +588,6 @@ static int bfin_crypto_crc_probe(struct platform_device *pdev)
 	crypto_init_queue(&crc->queue, CRC_CCRYPTO_QUEUE_LENGTH);
 	res = platform_get_resource(pdev, IORESOURCE_MEM, 0);
-		dev_err(&pdev->dev, "Cannot get IORESOURCE_MEM\n");
-		return -ENOENT;
 	crc->regs = devm_ioremap_resource(dev, res);
 	if (IS_ERR((void *)crc->regs)) {
 		dev_err(&pdev->dev, "Cannot map CRC IO\n");
BtrLinux
Privacy Overview
