crypto: atmel-aes – adjust duplicate test
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Delete successive tests to the same location.  The code tested the result
of a previous allocation, that itself was already tested.  It is changed to
test the result of the most recent allocation.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
@s exists@
local idexpression y;
expression x,e;
*if ( \(x == NULL\|IS_ERR(x)\|y != 0\) )
 { ... when forall
   return ...; }
... when != \(y = e\|y += e\|y -= e\|y |= e\|y &= e\|y++\|y--\|&y\)
    when != \(XT_GETPAGE(...,y)\|WMI_CMD_BUF(...)\)
 { ... when forall
   return ...; }
Signed-off-by: Julia Lawall
Acked-by: David S. Miller
Signed-off-by: Herbert Xu
 drivers/crypto/atmel-aes.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/crypto/atmel-aes.c b/drivers/crypto/atmel-aes.c
index 8061336..fe19bae 100644
--- a/drivers/crypto/atmel-aes.c
+++ b/drivers/crypto/atmel-aes.c
@@ -332,7 +332,7 @@ static int atmel_aes_crypt_cpu_start(struct atmel_aes_dev *dd)
 		return -EINVAL;
 	dd->nb_out_sg = atmel_aes_sg_length(dd->req, dd->out_sg);
-	if (!dd->nb_in_sg)
+	if (!dd->nb_out_sg)
 		return -EINVAL;
 	dd->bufcnt = sg_copy_to_buffer(dd->in_sg, dd->nb_in_sg,
BtrLinux
Privacy Overview
