crypto: arm – replace memset by memzero_explicit
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Memset on a local variable may be removed when it is called just before the
variable goes out of scope. Using memzero_explicit defeats this
optimization. A simplified version of the semantic patch that makes this
change is as follows: (http://coccinelle.lip6.fr/)
identifier x;
type T;
... when any
T x[...];
... when any
when exists
- memset
+ memzero_explicit
(x,
-0,
... when != x
when strict
This change was suggested by Daniel Borkmann
Signed-off-by: Julia Lawall
Acked-by: Ard Biesheuvel
Signed-off-by: Herbert Xu
arch/arm/crypto/sha512_neon_glue.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/crypto/sha512_neon_glue.c b/arch/arm/crypto/sha512_neon_glue.c
index f3452c6..b124dce 100644
--- a/arch/arm/crypto/sha512_neon_glue.c
+++ b/arch/arm/crypto/sha512_neon_glue.c
@@ -241,7 +241,7 @@ static int sha384_neon_final(struct shash_desc *desc, u8 *hash)
sha512_neon_final(desc, D);
memcpy(hash, D, SHA384_DIGEST_SIZE);
- memset(D, 0, SHA512_DIGEST_SIZE);
+ memzero_explicit(D, SHA512_DIGEST_SIZE);
return 0;
return 0;
