cpupower: Remove redundant error check
Author: Peter Senna Tschudin <peter.senna@gmail.com>
Remove double checks, and move the call to print_error to the
first check. Replace break by return, and return 0 on success.
The simplified version of the coccinelle semantic patch that
fixes this issue is as follows:
expression E; identifier pr; expression list es;
for(...;...;...){
-	if (E) break;
+	if (E){
+		pr(es);
+		break;
- if(E) pr(es);
Signed-off-by: Peter Senna Tschudin
Signed-off-by: Thomas Renninger
Signed-off-by: Rafael J. Wysocki
 tools/power/cpupower/utils/cpufreq-set.c | 11 +++++------
 1 file changed, 5 insertions(+), 6 deletions(-)
diff --git a/tools/power/cpupower/utils/cpufreq-set.c b/tools/power/cpupower/utils/cpufreq-set.c
index a416de8..f656e58 100644
--- a/tools/power/cpupower/utils/cpufreq-set.c
+++ b/tools/power/cpupower/utils/cpufreq-set.c
@@ -320,12 +320,11 @@ int cmd_freq_set(int argc, char **argv)
 		printf(_("Setting cpu: %d\n"), cpu);
 		ret = do_one_cpu(cpu, &new_pol, freq, policychange);
-		if (ret)
-			break;
+		if (ret) {
+			print_error();
+			return ret;
-	if (ret)
-		print_error();
-	return ret;
+	return 0;
BtrLinux
Privacy Overview
