cpufreq-dt: fix handling regulator_get_voltage() result
Author: Andrzej Hajda <a.hajda@samsung.com>
The function can return negative values so it should be assigned
to signed type.
The problem has been detected using proposed semantic patch
scripts/coccinelle/tests/unsigned_lesser_than_zero.cocci.
Link: http://permalink.gmane.org/gmane.linux.kernel/2038576
Signed-off-by: Andrzej Hajda
Acked-by: Viresh Kumar
Signed-off-by: Rafael J. Wysocki
 drivers/cpufreq/cpufreq-dt.c | 5 +++--
 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/drivers/cpufreq/cpufreq-dt.c b/drivers/cpufreq/cpufreq-dt.c
index 1ceece9..9bc37c4 100644
--- a/drivers/cpufreq/cpufreq-dt.c
+++ b/drivers/cpufreq/cpufreq-dt.c
@@ -50,7 +50,8 @@ static int set_target(struct cpufreq_policy *policy, unsigned int index)
 	struct private_data *priv = policy->driver_data;
 	struct device *cpu_dev = priv->cpu_dev;
 	struct regulator *cpu_reg = priv->cpu_reg;
-	unsigned long volt = 0, volt_old = 0, tol = 0;
+	unsigned long volt = 0, tol = 0;
+	int volt_old = 0;
 	unsigned int old_freq, new_freq;
 	long freq_Hz, freq_exact;
 	int ret;
@@ -83,7 +84,7 @@ static int set_target(struct cpufreq_policy *policy, unsigned int index)
 			opp_freq / 1000, volt);
-	dev_dbg(cpu_dev, "%u MHz, %ld mV --> %u MHz, %ld mV\n",
+	dev_dbg(cpu_dev, "%u MHz, %d mV --> %u MHz, %ld mV\n",
 		old_freq / 1000, (volt_old > 0) ? volt_old / 1000 : -1,
 		new_freq / 1000, volt ? volt / 1000 : -1);
