cpufreq-dt: Drop unnecessary check before cpufreq_cooling_unregister() invocation
Author: Markus Elfring <elfring@users.sourceforge.net>
The cpufreq_cooling_unregister() function tests whether its argument is NULL
and then returns immediately. Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
[ rjw: Subject ]
Signed-off-by: Rafael J. Wysocki
 drivers/cpufreq/cpufreq-dt.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/cpufreq/cpufreq-dt.c b/drivers/cpufreq/cpufreq-dt.c
index fde97d6..bab67db 100644
--- a/drivers/cpufreq/cpufreq-dt.c
+++ b/drivers/cpufreq/cpufreq-dt.c
@@ -320,8 +320,7 @@ static int cpufreq_exit(struct cpufreq_policy *policy)
 	struct private_data *priv = policy->driver_data;
-	if (priv->cdev)
-		cpufreq_cooling_unregister(priv->cdev);
+	cpufreq_cooling_unregister(priv->cdev);
 	dev_pm_opp_free_cpufreq_table(priv->cpu_dev, &policy->freq_table);
 	of_free_opp_table(priv->cpu_dev);
 	clk_put(policy->clk);
BtrLinux
Privacy Overview
