[CPUFREQ] drivers/cpufreq/cpufreq.c: Adjust error handling code involving cpufreq_cpu_put
After calling cpufreq_cpu_get, error handling code should call
cpufreq_cpu_put.
The semantic match that finds this problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@r@
expression x,E;
statement S;
position p1,p2,p3;
if ((x = cpufreq_cpu_get@p1(...)) == NULL || ...) S
... when != x
if (x == NULL || ...) S
if@p3 (...) { ... when != cpufreq_cpu_put(x)
                  when != if (x) { ... cpufreq_cpu_put(x); ...}
    return@p2 ...;
return x;
return 0;
x = E
E = x
cpufreq_cpu_put(x)
@exists@
position r.p1,r.p2,r.p3;
expression x;
int ret != 0;
statement S;
* x = cpufreq_cpu_get@p1(...)
* if@p3 (...)
  S
* return@p2 \(NULL\|ret\);
Signed-off-by: Julia Lawall
Signed-off-by: Dave Jones
 drivers/cpufreq/cpufreq.c | 24 ++++++++++++++++--------
 1 file changed, 16 insertions(+), 8 deletions(-)
diff --git a/drivers/cpufreq/cpufreq.c b/drivers/cpufreq/cpufreq.c
index 8a67f16..9bbdc25 100644
--- a/drivers/cpufreq/cpufreq.c
+++ b/drivers/cpufreq/cpufreq.c
@@ -1467,20 +1467,22 @@ int cpufreq_driver_target(struct cpufreq_policy *policy,
 			  unsigned int target_freq,
 			  unsigned int relation)
-	int ret;
+	int ret = -EINVAL;
 	policy = cpufreq_cpu_get(policy->cpu);
 	if (!policy)
-		return -EINVAL;
+		goto no_policy;
 	if (unlikely(lock_policy_rwsem_write(policy->cpu)))
-		return -EINVAL;
+		goto fail;
 	ret = __cpufreq_driver_target(policy, target_freq, relation);
 	unlock_policy_rwsem_write(policy->cpu);
+fail:
 	cpufreq_cpu_put(policy);
+no_policy:
 	return ret;
 EXPORT_SYMBOL_GPL(cpufreq_driver_target);
@@ -1717,13 +1719,17 @@ int cpufreq_update_policy(unsigned int cpu)
 	struct cpufreq_policy *data = cpufreq_cpu_get(cpu);
 	struct cpufreq_policy policy;
-	int ret = 0;
+	int ret;
-	if (!data)
-		return -ENODEV;
+	if (!data) {
+		ret = -ENODEV;
+		goto no_policy;
-	if (unlikely(lock_policy_rwsem_write(cpu)))
-		return -EINVAL;
+	if (unlikely(lock_policy_rwsem_write(cpu))) {
+		ret = -EINVAL;
+		goto fail;
 	dprintk("updating policy for CPU %u\n", cpu);
 	memcpy(&policy, data, sizeof(struct cpufreq_policy));
@@ -1750,7 +1756,9 @@ int cpufreq_update_policy(unsigned int cpu)
 	unlock_policy_rwsem_write(cpu);
+fail:
 	cpufreq_cpu_put(data);
+no_policy:
 	return ret;
 EXPORT_SYMBOL(cpufreq_update_policy);
BtrLinux
Privacy Overview
