com20020_cs: Remove typedef com20020_dev_t
Author: Himangi Saraogi <himangi774@gmail.com>
The Linux kernel coding style guidelines suggest not using typedefs
for structure types. This patch gets rid of the typedef for
com20020_dev_t. Also, the name of the struct is changed to drop the
_t, to make the name look less typedef-like.
The following Coccinelle semantic patch detects the case:
@tn@
identifier i;
type td;
-typedef
 struct i { ... }
-td
type tn.td;
identifier tn.i;
-td
+ struct i
Signed-off-by: Himangi Saraogi
Acked-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/net/arcnet/com20020_cs.c | 16 ++++++++--------
 1 file changed, 8 insertions(+), 8 deletions(-)
diff --git a/drivers/net/arcnet/com20020_cs.c b/drivers/net/arcnet/com20020_cs.c
index 326a612..1a790a2 100644
--- a/drivers/net/arcnet/com20020_cs.c
+++ b/drivers/net/arcnet/com20020_cs.c
@@ -112,20 +112,20 @@ static void com20020_detach(struct pcmcia_device *p_dev);
-typedef struct com20020_dev_t {
+struct com20020_dev {
     struct net_device       *dev;
-} com20020_dev_t;
 static int com20020_probe(struct pcmcia_device *p_dev)
-    com20020_dev_t *info;
+    struct com20020_dev *info;
     struct arcnet_local *lp;
     dev_dbg(&p_dev->dev, "com20020_attach()\n");
     /* Create new network device */
-    info = kzalloc(sizeof(struct com20020_dev_t), GFP_KERNEL);
+    info = kzalloc(sizeof(*info), GFP_KERNEL);
     if (!info)
 	goto fail_alloc_info;
@@ -160,7 +160,7 @@ fail_alloc_info:
 static void com20020_detach(struct pcmcia_device *link)
-    struct com20020_dev_t *info = link->priv;
+    struct com20020_dev *info = link->priv;
     struct net_device *dev = info->dev;
     dev_dbg(&link->dev, "detach...\n");
@@ -199,7 +199,7 @@ static void com20020_detach(struct pcmcia_device *link)
 static int com20020_config(struct pcmcia_device *link)
     int i, ret;
     int ioaddr;
@@ -291,7 +291,7 @@ static void com20020_release(struct pcmcia_device *link)
 static int com20020_suspend(struct pcmcia_device *link)
-	com20020_dev_t *info = link->priv;
 	if (link->open)
@@ -302,7 +302,7 @@ static int com20020_suspend(struct pcmcia_device *link)
 static int com20020_resume(struct pcmcia_device *link)
 	if (link->open) {
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
