clk: vt8500: fix sign of possible PLL values
Author: Andrzej Hajda <a.hajda@samsung.com>
With unsigned values underflow in loops can occur resulting in
theoretically infinite loops.
The problem has been detected using proposed semantic patch
scripts/coccinelle/tests/unsigned_lesser_than_zero.cocci [1].
[1]: http://permalink.gmane.org/gmane.linux.kernel/2038576
Signed-off-by: Andrzej Hajda
Signed-off-by: Stephen Boyd
 drivers/clk/clk-vt8500.c | 9 ++++++---
 1 file changed, 6 insertions(+), 3 deletions(-)
diff --git a/drivers/clk/clk-vt8500.c b/drivers/clk/clk-vt8500.c
index 37e9288..98c4492 100644
--- a/drivers/clk/clk-vt8500.c
+++ b/drivers/clk/clk-vt8500.c
@@ -384,7 +384,8 @@ static void vt8500_find_pll_bits(unsigned long rate, unsigned long parent_rate,
 static void wm8650_find_pll_bits(unsigned long rate, unsigned long parent_rate,
 				u32 *multiplier, u32 *divisor1, u32 *divisor2)
-	u32 mul, div1, div2;
+	u32 mul, div1;
+	int div2;
 	u32 best_mul, best_div1, best_div2;
 	unsigned long tclk, rate_err, best_err;
@@ -452,7 +453,8 @@ static u32 wm8750_get_filter(u32 parent_rate, u32 divisor1)
 static void wm8750_find_pll_bits(unsigned long rate, unsigned long parent_rate,
 				u32 *filter, u32 *multiplier, u32 *divisor1, u32 *divisor2)
+	u32 mul;
+	int div1, div2;
@@ -496,7 +498,8 @@ static void wm8750_find_pll_bits(unsigned long rate, unsigned long parent_rate,
 static void wm8850_find_pll_bits(unsigned long rate, unsigned long parent_rate,
+	u32 mul;
+	int div1, div2;
BtrLinux
Privacy Overview
