clk: tegra: delete unneeded of_node_put
Author: Julia Lawall <Julia.Lawall@lip6.fr>
for_each_child_of_node performs an of_node_put on each iteration, so
putting an of_node_put before a continue results in a double put.
The semantic match that finds this problem is as follows
(http://coccinelle.lip6.fr):
expression root,e;
local idexpression child;
iterator name for_each_child_of_node;
for_each_child_of_node(root, child) {
... when != of_node_get(child)
* of_node_put(child);
* continue;
Signed-off-by: Julia Lawall
Signed-off-by: Stephen Boyd
drivers/clk/tegra/clk-emc.c | 4 +---
1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/drivers/clk/tegra/clk-emc.c b/drivers/clk/tegra/clk-emc.c
index 138a94b..e1fe8f3 100644
--- a/drivers/clk/tegra/clk-emc.c
+++ b/drivers/clk/tegra/clk-emc.c
@@ -491,10 +491,8 @@ struct clk *tegra_clk_register_emc(void __iomem *base, struct device_node *np,
for_each_child_of_node(np, node) {
err = of_property_read_u32(node, "nvidia,ram-code",
&node_ram_code);
- if (err) {
- of_node_put(node);
+ if (err)
continue;
* Store timings for all ram codes as we cannot read the |
&node_ram_code);
- if (err) {
+ if (err)
continue;
