clk: tegra: Add missing of_node_put()
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
for_each_child_of_node() performs an of_node_get() on each iteration, so
before breaking out of the loop an of_node_put() is required.
Found using Coccinelle. The semantic patch used for this is as follows:
expression e;
local idexpression child;
 for_each_child_of_node(root, child) {
   ... when != of_node_put(child)
       when != e = child
   return child;
+  of_node_put(child);
?  return ...;
Signed-off-by: Amitoj Kaur Chawla
Signed-off-by: Thierry Reding
 drivers/clk/tegra/clk-emc.c | 6 ++++--
 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/drivers/clk/tegra/clk-emc.c b/drivers/clk/tegra/clk-emc.c
index e1fe8f3..74e7544 100644
--- a/drivers/clk/tegra/clk-emc.c
+++ b/drivers/clk/tegra/clk-emc.c
@@ -450,8 +450,10 @@ static int load_timings_from_dt(struct tegra_clk_emc *tegra,
 		struct emc_timing *timing = tegra->timings + (i++);
 		err = load_one_timing_from_dt(tegra, timing, child);
-		if (err)
+		if (err) {
 			return err;
 		timing->ram_code = ram_code;
@@ -499,9 +501,9 @@ struct clk *tegra_clk_register_emc(void __iomem *base, struct device_node *np,
 		 * fuses until the apbmisc driver is loaded.
 		err = load_timings_from_dt(tegra, node, node_ram_code);
+		of_node_put(node);
 		if (err)
 			return ERR_PTR(err);
-		of_node_put(node);
 		break;
BtrLinux
Privacy Overview
