chelsio: fix misspelling of current function in string
Author: Julia Lawall <julia.lawall@lip6.fr>
Replace a misspelled function name by %s and then __func__.
This was done using Coccinelle, including the use of Levenshtein distance,
as proposed by Rasmus Villemoes.
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/net/ethernet/chelsio/cxgb/sge.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/ethernet/chelsio/cxgb/sge.c b/drivers/net/ethernet/chelsio/cxgb/sge.c
index 4c58793..86222a1 100644
--- a/drivers/net/ethernet/chelsio/cxgb/sge.c
+++ b/drivers/net/ethernet/chelsio/cxgb/sge.c
@@ -301,7 +301,7 @@ unsigned int t1_sched_update_parms(struct sge *sge, unsigned int port,
 	struct sched_port *p = &s->p[port];
 	unsigned int max_avail_segs;
-	pr_debug("t1_sched_update_params mtu=%d speed=%d\n", mtu, speed);
+	pr_debug("%s mtu=%d speed=%d\n", __func__, mtu, speed);
 	if (speed)
 		p->speed = speed;
 	if (mtu)
BtrLinux
Privacy Overview
