char: tpm: Deletion of unnecessary checks before the function call “tpm_dev_vendor_release”
Author: Markus Elfring <elfring@users.sourceforge.net>
The tpm_dev_vendor_release() function tests whether its argument is NULL
and then returns immediately. Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Peter Huewe
 drivers/char/tpm/tpm_i2c_atmel.c   | 3 +--
 drivers/char/tpm/tpm_i2c_nuvoton.c | 3 +--
 2 files changed, 2 insertions(+), 4 deletions(-)
diff --git a/drivers/char/tpm/tpm_i2c_atmel.c b/drivers/char/tpm/tpm_i2c_atmel.c
index 503a85a..5f44888 100644
--- a/drivers/char/tpm/tpm_i2c_atmel.c
+++ b/drivers/char/tpm/tpm_i2c_atmel.c
@@ -206,8 +206,7 @@ static int i2c_atmel_remove(struct i2c_client *client)
 	struct device *dev = &(client->dev);
 	struct tpm_chip *chip = dev_get_drvdata(dev);
-	if (chip)
-		tpm_dev_vendor_release(chip);
+	tpm_dev_vendor_release(chip);
 	tpm_remove_hardware(dev);
 	kfree(chip);
 	return 0;
diff --git a/drivers/char/tpm/tpm_i2c_nuvoton.c b/drivers/char/tpm/tpm_i2c_nuvoton.c
index 23c7b13..bbb4997 100644
--- a/drivers/char/tpm/tpm_i2c_nuvoton.c
+++ b/drivers/char/tpm/tpm_i2c_nuvoton.c
@@ -630,8 +630,7 @@ static int i2c_nuvoton_remove(struct i2c_client *client)
-	if (chip)
 	kfree(chip);
 	return 0;
BtrLinux
Privacy Overview
