CDC NCM: Use kzalloc rather than kmalloc followed by memset with 0
Author: Thomas Meyer <thomas@m3y3r.de>
This considers some simple cases that are common and easy to validate
Note in particular that there are no ...s in the rule, so all of the
matched code has to be contiguous
The semantic patch that makes this change is available
in scripts/coccinelle/api/alloc/kzalloc-simple.cocci.
Signed-off-by: Thomas Meyer
Signed-off-by: David S. Miller
 drivers/net/usb/cdc_ncm.c | 4 +---
 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/drivers/net/usb/cdc_ncm.c b/drivers/net/usb/cdc_ncm.c
index f06fb78..009dd0f 100644
--- a/drivers/net/usb/cdc_ncm.c
+++ b/drivers/net/usb/cdc_ncm.c
@@ -465,12 +465,10 @@ static int cdc_ncm_bind(struct usbnet *dev, struct usb_interface *intf)
 	int temp;
 	u8 iface_no;
-	ctx = kmalloc(sizeof(*ctx), GFP_KERNEL);
+	ctx = kzalloc(sizeof(*ctx), GFP_KERNEL);
 	if (ctx == NULL)
 		return -ENODEV;
-	memset(ctx, 0, sizeof(*ctx));
 	init_timer(&ctx->tx_timer);
 	spin_lock_init(&ctx->mtx);
 	ctx->netdev = dev->net;
BtrLinux
Privacy Overview
