carl9170: use ether_addr_equal_64bits
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Ether_addr_equal_64bits is more efficient than ether_addr_equal, and can be
used when each argument is an array within a structure that contains at
least two bytes of data beyond the array.
The structures involved are:
ieee80211_hdr defined in include/linux/ieee80211.h,
ieee80211_bar defined in include/linux/ieee80211.h and
ath_common defined in drivers/net/wireless/ath/ath.h
This was done using Coccinelle (http://coccinelle.lip6.fr/).
Signed-off-by: Julia Lawall
Acked-by: Christian Lamparter
Signed-off-by: John W. Linville
drivers/net/wireless/ath/carl9170/rx.c | 6 +++---
1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/net/wireless/ath/carl9170/rx.c b/drivers/net/wireless/ath/carl9170/rx.c
index e935f61..acd7ddc 100644
--- a/drivers/net/wireless/ath/carl9170/rx.c
+++ b/drivers/net/wireless/ath/carl9170/rx.c
@@ -536,7 +536,7 @@ static void carl9170_ps_beacon(struct ar9170 *ar, void *data, unsigned int len)
return;
/* and only beacons from the associated BSSID, please */
- if (!ether_addr_equal(hdr->addr3, ar->common.curbssid) ||
+ if (!ether_addr_equal_64bits(hdr->addr3, ar->common.curbssid) ||
!ar->common.curaid)
return;
@@ -602,8 +602,8 @@ static void carl9170_ba_check(struct ar9170 *ar, void *data, unsigned int len)
if (bar->start_seq_num == entry_bar->start_seq_num &&
TID_CHECK(bar->control, entry_bar->control) &&
- ether_addr_equal(bar->ra, entry_bar->ta) &&
- ether_addr_equal(bar->ta, entry_bar->ra)) {
+ ether_addr_equal_64bits(bar->ra, entry_bar->ta) &&
+ ether_addr_equal_64bits(bar->ta, entry_bar->ra)) {
struct ieee80211_tx_info *tx_info;
tx_info = IEEE80211_SKB_CB(entry_skb); |
return;
!ar->common.curaid)
return;
