CAPI: use correct structure type name in sizeof
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Correct typo in the name of the type given to sizeof.  Because it is the
size of a pointer that is wanted, the typo has no impact on compilation or
execution.
This problem was found using Coccinelle (http://coccinelle.lip6.fr/).  The
semantic patch used can be found in message 0 of this patch series.
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/isdn/capi/capi.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/isdn/capi/capi.c b/drivers/isdn/capi/capi.c
index f9a87ed..6a2df32 100644
--- a/drivers/isdn/capi/capi.c
+++ b/drivers/isdn/capi/capi.c
@@ -1260,7 +1260,7 @@ static int __init capinc_tty_init(void)
 	if (capi_ttyminors <= 0)
 		capi_ttyminors = CAPINC_NR_PORTS;
-	capiminors = kzalloc(sizeof(struct capi_minor *) * capi_ttyminors,
+	capiminors = kzalloc(sizeof(struct capiminor *) * capi_ttyminors,
 			     GFP_KERNEL);
 	if (!capiminors)
 		return -ENOMEM;
BtrLinux
Privacy Overview
