can: softing: softing_main: ensure a consistent return value in error case
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Typically, the return value desired for the failure of a function with an
integer return value is a negative integer. In these cases, the return
value is sometimes a negative integer and sometimes 0, due to a subsequent
initialization of the return variable within the loop.
A simplified version of the semantic match that finds this problem is:
(http://coccinelle.lip6.fr/)
@r exists@
identifier ret;
position p;
constant C;
expression e1,e3,e4;
statement S;
ret = -C
... when != ret = e3
when any
if@p (...) S
... when any
if (\(ret != 0\|ret < 0\|ret > 0\) || ...) { ... return ...; }
when any
*if@p (...)
... when != ret = e4
return ret;
Signed-off-by: Julia Lawall
Acked-by: Kurt Van Dijck
Signed-off-by: Marc Kleine-Budde
drivers/net/can/softing/softing_main.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/can/softing/softing_main.c b/drivers/net/can/softing/softing_main.c
index a7c77c74..f2a221e 100644
--- a/drivers/net/can/softing/softing_main.c
+++ b/drivers/net/can/softing/softing_main.c
@@ -826,12 +826,12 @@ static __devinit int softing_pdev_probe(struct platform_device *pdev)
goto sysfs_failed;
- ret = -ENOMEM;
for (j = 0; j < ARRAY_SIZE(card->net); ++j) {
card->net[j] = netdev =
softing_netdev_create(card, card->id.chip[j]);
if (!netdev) {
dev_alert(&pdev->dev, "failed to make can[%i]", j);
+ ret = -ENOMEM;
goto netdev_failed;
priv = netdev_priv(card->net[j]); |
goto sysfs_failed;
- ret = -ENOMEM;
if (!netdev) {
+ ret = -ENOMEM;
goto netdev_failed;
