bus: vexpress-config: Add missing of_node_put
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
for_each_compatible_node performs an of_node_get on each iteration, so
to break out of the loop an of_node_put is required.
Found using Coccinelle. The semantic patch used for this is as follows:
expression e;
local idexpression n;
 for_each_compatible_node(n, ...) {
   ... when != of_node_put(n)
       when != e = n
   return n;
+  of_node_put(n);
?  return ...;
Acked-by: Liviu Dudau
Signed-off-by: Amitoj Kaur Chawla
Signed-off-by: Sudeep Holla
 drivers/bus/vexpress-config.c | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/bus/vexpress-config.c b/drivers/bus/vexpress-config.c
index 6575c0f..c3cb76b 100644
--- a/drivers/bus/vexpress-config.c
+++ b/drivers/bus/vexpress-config.c
@@ -192,8 +192,10 @@ static int __init vexpress_config_init(void)
 	/* Need the config devices early, before the "normal" devices... */
 	for_each_compatible_node(node, NULL, "arm,vexpress,config-bus") {
 		err = vexpress_config_populate(node);
-		if (err)
+		if (err) {
+			of_node_put(node);
 			break;
 	return err;
BtrLinux
Privacy Overview
