Btrfs: using for_each_set_bit_from to simplify the code
Author: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Using for_each_set_bit_from() to simplify the code.
spatch with a semantic match is used to found this.
(http://coccinelle.lip6.fr/)
Signed-off-by: Wei Yongjun
fs/btrfs/free-space-cache.c | 8 ++------
1 file changed, 2 insertions(+), 6 deletions(-)
diff --git a/fs/btrfs/free-space-cache.c b/fs/btrfs/free-space-cache.c
index 6b10acf..b107e68 100644
--- a/fs/btrfs/free-space-cache.c
+++ b/fs/btrfs/free-space-cache.c
@@ -1454,9 +1454,7 @@ static int search_bitmap(struct btrfs_free_space_ctl *ctl,
max_t(u64, *offset, bitmap_info->offset));
bits = bytes_to_bits(*bytes, ctl->unit);
- for (i = find_next_bit(bitmap_info->bitmap, BITS_PER_BITMAP, i);
- i < BITS_PER_BITMAP;
- i = find_next_bit(bitmap_info->bitmap, BITS_PER_BITMAP, i + 1)) {
+ for_each_set_bit_from(i, bitmap_info->bitmap, BITS_PER_BITMAP) {
next_zero = find_next_zero_bit(bitmap_info->bitmap,
if ((next_zero - i) >= bits) {
@@ -2307,9 +2305,7 @@ static int btrfs_bitmap_cluster(struct btrfs_block_group_cache *block_group,
again:
found_bits = 0;
- for (i = find_next_bit(entry->bitmap, BITS_PER_BITMAP, i);
- i = find_next_bit(entry->bitmap, BITS_PER_BITMAP, i + 1)) {
+ for_each_set_bit_from(i, entry->bitmap, BITS_PER_BITMAP) {
next_zero = find_next_zero_bit(entry->bitmap,
if (next_zero - i >= min_bits) { |
again:
found_bits = 0;
