Btrfs: Use ERR_CAST helpers
Use ERR_CAST(x) rather than ERR_PTR(PTR_ERR(x)).  The former makes more
clear what is the purpose of the operation, which otherwise looks like a
no-op.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
type T;
T x;
identifier f;
T f (...) { <+...
- ERR_PTR(PTR_ERR(x))
+ x
expression x;
+ ERR_CAST(x)
Signed-off-by: Julia Lawall
Cc: Chris Mason
Signed-off-by: Andrew Morton
Signed-off-by: Chris Mason
 fs/btrfs/extent_map.c | 4 ++--
 fs/btrfs/super.c      | 2 +-
 2 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/fs/btrfs/extent_map.c b/fs/btrfs/extent_map.c
index 454ca52..23cb8da 100644
--- a/fs/btrfs/extent_map.c
+++ b/fs/btrfs/extent_map.c
@@ -335,7 +335,7 @@ struct extent_map *lookup_extent_mapping(struct extent_map_tree *tree,
 		goto out;
 	if (IS_ERR(rb_node)) {
-		em = ERR_PTR(PTR_ERR(rb_node));
+		em = ERR_CAST(rb_node);
 		goto out;
 	em = rb_entry(rb_node, struct extent_map, rb_node);
@@ -384,7 +384,7 @@ struct extent_map *search_extent_mapping(struct extent_map_tree *tree,
 		goto out;
 		goto out;
diff --git a/fs/btrfs/super.c b/fs/btrfs/super.c
index 65b62da..d7fb273 100644
--- a/fs/btrfs/super.c
+++ b/fs/btrfs/super.c
@@ -389,7 +389,7 @@ static struct dentry *get_default_root(struct super_block *sb,
 find_root:
 	new_root = btrfs_read_fs_root_no_name(root->fs_info, &location);
 	if (IS_ERR(new_root))
-		return ERR_PTR(PTR_ERR(new_root));
+		return ERR_CAST(new_root);
 	if (btrfs_root_refs(&new_root->root_item) == 0)
 		return ERR_PTR(-ENOENT);
