btrfs: simpilify btrfs_subvol_inherit_props
Author: Jeff Mahoney <jeffm@suse.com>
We just need a superblock, but we look it up using two different
roots depending on the call site.  Let's just use a superblock
pointer initialized at the outset.
This is mostly for Coccinelle not to choke on my root push up set.
Signed-off-by: Jeff Mahoney
Signed-off-by: David Sterba
 fs/btrfs/props.c | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/fs/btrfs/props.c b/fs/btrfs/props.c
index 3699212..cf0b444 100644
--- a/fs/btrfs/props.c
+++ b/fs/btrfs/props.c
@@ -350,6 +350,7 @@ int btrfs_subvol_inherit_props(struct btrfs_trans_handle *trans,
 			       struct btrfs_root *root,
 			       struct btrfs_root *parent_root)
+	struct super_block *sb = root->fs_info->sb;
 	struct btrfs_key key;
 	struct inode *parent_inode, *child_inode;
 	int ret;
@@ -358,12 +359,11 @@ int btrfs_subvol_inherit_props(struct btrfs_trans_handle *trans,
 	key.type = BTRFS_INODE_ITEM_KEY;
 	key.offset = 0;
-	parent_inode = btrfs_iget(parent_root->fs_info->sb, &key,
-				  parent_root, NULL);
+	parent_inode = btrfs_iget(sb, &key, parent_root, NULL);
 	if (IS_ERR(parent_inode))
 		return PTR_ERR(parent_inode);
-	child_inode = btrfs_iget(root->fs_info->sb, &key, root, NULL);
+	child_inode = btrfs_iget(sb, &key, root, NULL);
 	if (IS_ERR(child_inode)) {
 		iput(parent_inode);
 		return PTR_ERR(child_inode);
BtrLinux
Privacy Overview
