btrfs: fix signed overflows in btrfs_sync_file
Author: David Sterba <dsterba@suse.com>
The calculation of range length in btrfs_sync_file leads to signed
overflow. This was caught by PaX gcc SIZE_OVERFLOW plugin.
https://forums.grsecurity.net/viewtopic.php?f=1&t=4284
The fsync call passes 0 and LLONG_MAX, the range length does not fit to
loff_t and overflows, but the value is converted to u64 so it silently
works as expected.
The minimal fix is a typecast to u64, switching functions to take
(start, end) instead of (start, len) would be more intrusive.
Coccinelle script found that there's one more opencoded calculation of
the length.
loff_t start, end;
* end - start
CC: stable@vger.kernel.org
Signed-off-by: David Sterba
Signed-off-by: Chris Mason
 fs/btrfs/file.c | 10 +++++++---
 1 file changed, 7 insertions(+), 3 deletions(-)
diff --git a/fs/btrfs/file.c b/fs/btrfs/file.c
index 3009d45..8eb1f3c 100644
--- a/fs/btrfs/file.c
+++ b/fs/btrfs/file.c
@@ -1882,8 +1882,13 @@ int btrfs_sync_file(struct file *file, loff_t start, loff_t end, int datasync)
 	struct btrfs_log_ctx ctx;
 	int ret = 0;
 	bool full_sync = 0;
-	const u64 len = end - start + 1;
+	u64 len;
+	 * The range length can be represented by u64, we have to do the typecasts
+	 * to avoid signed overflow if it's [0, LLONG_MAX] eg. from fsync()
+	len = (u64)end - (u64)start + 1;
 	trace_btrfs_sync_file(file, datasync);
@@ -2071,8 +2076,7 @@ int btrfs_sync_file(struct file *file, loff_t start, loff_t end, int datasync)
 		if (!full_sync) {
-			ret = btrfs_wait_ordered_range(inode, start,
-						       end - start + 1);
+			ret = btrfs_wait_ordered_range(inode, start, len);
 			if (ret) {
 				btrfs_end_transaction(trans, root);
 				goto out;
BtrLinux
Privacy Overview
