brcmsmac: make return of 0 explicit
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Delete unnecessary local variable whose value is always 0 and that hides
the fact that the result is always 0.
A simplified version of the semantic patch that fixes this problem is as
follows: (http://coccinelle.lip6.fr/)
@r exists@
local idexpression ret;
expression e;
position p;
-ret = 0;
... when != ret = e
return
- ret
+ 0
Signed-off-by: Julia Lawall
[arend@broadcom.com: make brcms_b_detach() a void function]
Signed-off-by: Arend van Spriel
Signed-off-by: John W. Linville
 drivers/net/wireless/brcm80211/brcmsmac/main.c | 13 ++++---------
 1 file changed, 4 insertions(+), 9 deletions(-)
diff --git a/drivers/net/wireless/brcm80211/brcmsmac/main.c b/drivers/net/wireless/brcm80211/brcmsmac/main.c
index 9417cb5..af8ba64 100644
--- a/drivers/net/wireless/brcm80211/brcmsmac/main.c
+++ b/drivers/net/wireless/brcm80211/brcmsmac/main.c
@@ -4870,14 +4870,11 @@ static void brcms_c_detach_module(struct brcms_c_info *wlc)
  * low level detach
-static int brcms_b_detach(struct brcms_c_info *wlc)
+static void brcms_b_detach(struct brcms_c_info *wlc)
 	uint i;
 	struct brcms_hw_band *band;
 	struct brcms_hardware *wlc_hw = wlc->hw;
-	int callbacks;
-	callbacks = 0;
 	brcms_b_detach_dmapio(wlc_hw);
@@ -4900,9 +4897,6 @@ static int brcms_b_detach(struct brcms_c_info *wlc)
 		ai_detach(wlc_hw->sih);
 		wlc_hw->sih = NULL;
-	return callbacks;
@@ -4917,14 +4911,15 @@ static int brcms_b_detach(struct brcms_c_info *wlc)
 uint brcms_c_detach(struct brcms_c_info *wlc)
-	uint callbacks = 0;
+	uint callbacks;
 	if (wlc == NULL)
 		return 0;
-	callbacks += brcms_b_detach(wlc);
+	brcms_b_detach(wlc);
 	/* delete software timers */
+	callbacks = 0;
 	if (!brcms_c_radio_monitor_stop(wlc))
 		callbacks++;
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
