brcmfmac: Use put_unaligned_le32
Author: Vaishali Thakkar <vthakkar1994@gmail.com>
This patch introduces the use of function put_unaligned_le32.
This is done using Coccinelle and semantic patch used is as follows:
@a@
typedef u32, __le32, uint32_t;
{u32,__le32,uint32_t} e32;
identifier tmp;
expression ptr;
expression y,e;
type T;
type T;
- tmp = cpu_to_le32(y);
<+... when != tmp
- memcpy(ptr, (T)&tmp, \(4\|sizeof(u32)\|sizeof(__le32)\|sizeof(uint32_t)\|sizeof(e32)\));
+ put_unaligned_le32(y,ptr);
- memcpy(ptr, (T)&tmp, ...);
? tmp = e
@@ type T; identifier a.tmp; @@
- T tmp;
...when != tmp
Signed-off-by: Vaishali Thakkar
Signed-off-by: Kalle Valo
 drivers/net/wireless/brcm80211/brcmfmac/cfg80211.c | 9 ++-------
 1 file changed, 2 insertions(+), 7 deletions(-)
diff --git a/drivers/net/wireless/brcm80211/brcmfmac/cfg80211.c b/drivers/net/wireless/brcm80211/brcmfmac/cfg80211.c
index ebe6543..5eba81b 100644
--- a/drivers/net/wireless/brcm80211/brcmfmac/cfg80211.c
+++ b/drivers/net/wireless/brcm80211/brcmfmac/cfg80211.c
@@ -3737,17 +3737,12 @@ static u32
 brcmf_vndr_ie(u8 *iebuf, s32 pktflag, u8 *ie_ptr, u32 ie_len, s8 *add_del_cmd)
-	__le32 iecount_le;
-	__le32 pktflag_le;
 	strncpy(iebuf, add_del_cmd, VNDR_IE_CMD_LEN - 1);
 	iebuf[VNDR_IE_CMD_LEN - 1] = '\0';
-	iecount_le = cpu_to_le32(1);
-	memcpy(&iebuf[VNDR_IE_COUNT_OFFSET], &iecount_le, sizeof(iecount_le));
+	put_unaligned_le32(1, &iebuf[VNDR_IE_COUNT_OFFSET]);
-	pktflag_le = cpu_to_le32(pktflag);
-	memcpy(&iebuf[VNDR_IE_PKTFLAG_OFFSET], &pktflag_le, sizeof(pktflag_le));
+	put_unaligned_le32(pktflag, &iebuf[VNDR_IE_PKTFLAG_OFFSET]);
 	memcpy(&iebuf[VNDR_IE_VSIE_OFFSET], ie_ptr, ie_len);
BtrLinux
Privacy Overview
