br_multicast: Replace rcu_assign_pointer() with RCU_INIT_POINTER()
Author: Andreea-Cristina Bernat <bernat.ada@gmail.com>
The use of "rcu_assign_pointer()" is NULLing out the pointer.
According to RCU_INIT_POINTER()'s block comment:
"1.   This use of RCU_INIT_POINTER() is NULLing out the pointer"
it is better to use it instead of rcu_assign_pointer() because it has a
smaller overhead.
The following Coccinelle semantic patch was used:
- rcu_assign_pointer
+ RCU_INIT_POINTER
  (..., NULL)
Signed-off-by: Andreea-Cristina Bernat
Signed-off-by: David S. Miller
 net/bridge/br_multicast.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/net/bridge/br_multicast.c b/net/bridge/br_multicast.c
index 7751c92..648d79c 100644
--- a/net/bridge/br_multicast.c
+++ b/net/bridge/br_multicast.c
@@ -1822,7 +1822,7 @@ static void br_multicast_query_expired(struct net_bridge *br,
 	if (query->startup_sent < br->multicast_startup_query_count)
 		query->startup_sent++;
-	rcu_assign_pointer(querier, NULL);
+	RCU_INIT_POINTER(querier, NULL);
 	br_multicast_send_query(br, NULL, query);
 	spin_unlock(&br->multicast_lock);
BtrLinux
Privacy Overview
