bq27x00_battery: Fix error return code
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Initialize return variable before exiting on an error path.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
if@p1 (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret@p1 = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Julia Lawall
Signed-off-by: Anton Vorontsov
 drivers/power/bq27x00_battery.c | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/power/bq27x00_battery.c b/drivers/power/bq27x00_battery.c
index 181ddec..5860d4d 100644
--- a/drivers/power/bq27x00_battery.c
+++ b/drivers/power/bq27x00_battery.c
@@ -814,7 +814,8 @@ static int bq27x00_battery_probe(struct i2c_client *client,
 	di->bat.name = name;
 	di->bus.read = &bq27x00_read_i2c;
-	if (bq27x00_powersupply_init(di))
+	retval = bq27x00_powersupply_init(di);
+	if (retval)
 		goto batt_failed_3;
 	i2c_set_clientdata(client, di);
BtrLinux
Privacy Overview
