[BLUETOOTH]: Use sockfd_put()
The function sockfd_lookup uses fget on the value that is stored in
the file field of the returned structure, so fput should ultimately be
applied to this value.  This can be done directly, but it seems better
to use the specific macro sockfd_put, which does the same thing.
The problem was fixed using the following semantic patch.
(http://www.emn.fr/x-info/coccinelle/)
expression s;
   s = sockfd_lookup(...)
+  sockfd_put(s);
?- fput(s->file);
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 net/bluetooth/bnep/sock.c |  4 ++--
 net/bluetooth/cmtp/sock.c |  4 ++--
 net/bluetooth/hidp/sock.c | 10 +++++-----
 3 files changed, 9 insertions(+), 9 deletions(-)
diff --git a/net/bluetooth/bnep/sock.c b/net/bluetooth/bnep/sock.c
index 9ebd3c6..81065e5 100644
--- a/net/bluetooth/bnep/sock.c
+++ b/net/bluetooth/bnep/sock.c
@@ -94,7 +94,7 @@ static int bnep_sock_ioctl(struct socket *sock, unsigned int cmd, unsigned long
 			return err;
 		if (nsock->sk->sk_state != BT_CONNECTED) {
-			fput(nsock->file);
+			sockfd_put(nsock);
 			return -EBADFD;
@@ -103,7 +103,7 @@ static int bnep_sock_ioctl(struct socket *sock, unsigned int cmd, unsigned long
 			if (copy_to_user(argp, &ca, sizeof(ca)))
 				err = -EFAULT;
 		} else
 		return err;
diff --git a/net/bluetooth/cmtp/sock.c b/net/bluetooth/cmtp/sock.c
index 783edab..8c7f7bc 100644
--- a/net/bluetooth/cmtp/sock.c
+++ b/net/bluetooth/cmtp/sock.c
@@ -88,7 +88,7 @@ static int cmtp_sock_ioctl(struct socket *sock, unsigned int cmd, unsigned long
 			return err;
 			return -EBADFD;
@@ -97,7 +97,7 @@ static int cmtp_sock_ioctl(struct socket *sock, unsigned int cmd, unsigned long
 				err = -EFAULT;
 		} else
 		return err;
diff --git a/net/bluetooth/hidp/sock.c b/net/bluetooth/hidp/sock.c
index 3292b95..f4dd02c 100644
--- a/net/bluetooth/hidp/sock.c
+++ b/net/bluetooth/hidp/sock.c
@@ -86,13 +86,13 @@ static int hidp_sock_ioctl(struct socket *sock, unsigned int cmd, unsigned long
 		isock = sockfd_lookup(ca.intr_sock, &err);
 		if (!isock) {
-			fput(csock->file);
+			sockfd_put(csock);
 			return err;
 		if (csock->sk->sk_state != BT_CONNECTED || isock->sk->sk_state != BT_CONNECTED) {
-			fput(isock->file);
+			sockfd_put(isock);
 			return -EBADFD;
@@ -101,8 +101,8 @@ static int hidp_sock_ioctl(struct socket *sock, unsigned int cmd, unsigned long
 				err = -EFAULT;
 		} else {
 		return err;
BtrLinux
Privacy Overview
