Bluetooth: Use kzalloc for drivers
Use kzalloc rather than the combination of kmalloc and memset.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
expression x,size,flags;
statement S;
-x = kmalloc(size,flags);
+x = kzalloc(size,flags);
 if (x == NULL) S
-memset(x, 0, size);
Signed-off-by: Julia Lawall
Acked-by: Gustavo F. Padovan
Signed-off-by: Marcel Holtmann
 drivers/bluetooth/btmrvl_sdio.c | 8 ++------
 1 file changed, 2 insertions(+), 6 deletions(-)
diff --git a/drivers/bluetooth/btmrvl_sdio.c b/drivers/bluetooth/btmrvl_sdio.c
index 182e553..dcc2a6e 100644
--- a/drivers/bluetooth/btmrvl_sdio.c
+++ b/drivers/bluetooth/btmrvl_sdio.c
@@ -217,7 +217,7 @@ static int btmrvl_sdio_download_helper(struct btmrvl_sdio_card *card)
 	tmphlprbufsz = ALIGN_SZ(BTM_UPLD_SIZE, BTSDIO_DMA_ALIGN);
-	tmphlprbuf = kmalloc(tmphlprbufsz, GFP_KERNEL);
+	tmphlprbuf = kzalloc(tmphlprbufsz, GFP_KERNEL);
 	if (!tmphlprbuf) {
 		BT_ERR("Unable to allocate buffer for helper."
 			" Terminating download");
@@ -225,8 +225,6 @@ static int btmrvl_sdio_download_helper(struct btmrvl_sdio_card *card)
 		goto done;
-	memset(tmphlprbuf, 0, tmphlprbufsz);
 	helperbuf = (u8 *) ALIGN_ADDR(tmphlprbuf, BTSDIO_DMA_ALIGN);
 	/* Perform helper data transfer */
@@ -319,7 +317,7 @@ static int btmrvl_sdio_download_fw_w_helper(struct btmrvl_sdio_card *card)
 	BT_DBG("Downloading FW image (%d bytes)", firmwarelen);
 	tmpfwbufsz = ALIGN_SZ(BTM_UPLD_SIZE, BTSDIO_DMA_ALIGN);
-	tmpfwbuf = kmalloc(tmpfwbufsz, GFP_KERNEL);
+	tmpfwbuf = kzalloc(tmpfwbufsz, GFP_KERNEL);
 	if (!tmpfwbuf) {
 		BT_ERR("Unable to allocate buffer for firmware."
@@ -327,8 +325,6 @@ static int btmrvl_sdio_download_fw_w_helper(struct btmrvl_sdio_card *card)
 		goto done;
-	memset(tmpfwbuf, 0, tmpfwbufsz);
 	/* Ensure aligned firmware buffer */
 	fwbuf = (u8 *) ALIGN_ADDR(tmpfwbuf, BTSDIO_DMA_ALIGN);
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
