Bluetooth: Use kmemdup for drivers
Use kmemdup when some other buffer is immediately copied into the
allocated region.
A simplified version of the semantic patch that makes this change is as
follows: (http://coccinelle.lip6.fr/)
expression from,to,size,flag;
statement S;
-  to = \(kmalloc\|kzalloc\)(size,flag);
+  to = kmemdup(from,size,flag);
   if (to==NULL || ...) S
-  memcpy(to, from, size);
Signed-off-by: Julia Lawall
Acked-by: Gustavo F. Padovan
Signed-off-by: Marcel Holtmann
 drivers/bluetooth/bcm203x.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/bluetooth/bcm203x.c b/drivers/bluetooth/bcm203x.c
index b0c84c1..8b1b643 100644
--- a/drivers/bluetooth/bcm203x.c
+++ b/drivers/bluetooth/bcm203x.c
@@ -224,7 +224,7 @@ static int bcm203x_probe(struct usb_interface *intf, const struct usb_device_id
 	BT_DBG("firmware data %p size %zu", firmware->data, firmware->size);
-	data->fw_data = kmalloc(firmware->size, GFP_KERNEL);
+	data->fw_data = kmemdup(firmware->data, firmware->size, GFP_KERNEL);
 	if (!data->fw_data) {
 		BT_ERR("Can't allocate memory for firmware image");
 		release_firmware(firmware);
@@ -234,7 +234,6 @@ static int bcm203x_probe(struct usb_interface *intf, const struct usb_device_id
 		return -ENOMEM;
-	memcpy(data->fw_data, firmware->data, firmware->size);
 	data->fw_size = firmware->size;
 	data->fw_sent = 0;
BtrLinux
Privacy Overview
