Bluetooth: Make USB device id constant
Author: Márton Németh <nm127@freemail.hu>
The id_table field of the struct usb_device_id is constant in
so it is worth to make bcm203x_table also constant.
The semantic match that finds this kind of pattern is as follows:
(http://coccinelle.lip6.fr/)
@r@
disable decl_init,const_decl_init;
identifier I1, I2, x;
	struct I1 {
	  const struct I2 *x;
@s@
identifier r.I1, y;
identifier r.x, E;
	struct I1 y = {
	  .x = E,
@c@
identifier r.I2;
identifier s.E;
	const struct I2 E[] = ... ;
@depends on !c@
identifier r.I2;
identifier s.E;
+	const
	struct I2 E[] = ...;
Signed-off-by: Márton Németh
Cc: Julia Lawall
Cc: cocci@diku.dk
Signed-off-by: Marcel Holtmann
 drivers/bluetooth/bcm203x.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/bluetooth/bcm203x.c b/drivers/bluetooth/bcm203x.c
index eafd4af..b0c84c1 100644
--- a/drivers/bluetooth/bcm203x.c
+++ b/drivers/bluetooth/bcm203x.c
@@ -39,7 +39,7 @@
 #define VERSION "1.2"
-static struct usb_device_id bcm203x_table[] = {
+static const struct usb_device_id bcm203x_table[] = {
 	/* Broadcom Blutonium (BCM2033) */
 	{ USB_DEVICE(0x0a5c, 0x2033) },
BtrLinux
Privacy Overview
