Bluetooth: cmtp: Remove unnecessary null test
Author: Himangi Saraogi <himangi774@gmail.com>
This patch removes the null test on ctrl. ctrl is initialized at the
beginning of the function to &session->ctrl. Since session is
dereferenced prior to the null test, session must be a valid pointer,
and &session->ctrl cannot be null.
The following Coccinelle script is used for detecting the change:
@r@
expression e,f;
identifier g,y;
statement S1,S2;
*e = &f->g
f->y
*if (e != NULL || ...)
S1 else S2
Signed-off-by: Himangi Saraogi
Acked-by: Julia Lawall
Signed-off-by: Marcel Holtmann
net/bluetooth/cmtp/capi.c | 6 ------
1 file changed, 6 deletions(-)
diff --git a/net/bluetooth/cmtp/capi.c b/net/bluetooth/cmtp/capi.c
index cd75e4d..1ca8a87 100644
--- a/net/bluetooth/cmtp/capi.c
+++ b/net/bluetooth/cmtp/capi.c
@@ -362,12 +362,6 @@ void cmtp_recv_capimsg(struct cmtp_session *session, struct sk_buff *skb)
CAPIMSG_SETCONTROL(skb->data, contr);
- if (!ctrl) {
- BT_ERR("Can't find controller %d for message", session->num);
- kfree_skb(skb);
- return;
capi_ctr_handle_message(ctrl, appl, skb);
- if (!ctrl) {
- kfree_skb(skb);
- return;
