Bluetooth: btmrvl: add missing of_node_put
Author: Julia Lawall <Julia.Lawall@lip6.fr>
for_each_compatible_node performs an of_node_get on each iteration, so
a break out of the loop requires an of_node_put.
A simplified version of the semantic patch that fixes this problem is as
follows (http://coccinelle.lip6.fr):
expression e;
local idexpression n;
 for_each_compatible_node(n, ...) {
   ... when != of_node_put(n)
       when != e = n
   return n;
+  of_node_put(n);
?  return ...;
Signed-off-by: Julia Lawall
Signed-off-by: Marcel Holtmann
 drivers/bluetooth/btmrvl_main.c | 5 ++++-
 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/drivers/bluetooth/btmrvl_main.c b/drivers/bluetooth/btmrvl_main.c
index 6ba2286..6af9173 100644
--- a/drivers/bluetooth/btmrvl_main.c
+++ b/drivers/bluetooth/btmrvl_main.c
@@ -516,14 +516,17 @@ static int btmrvl_check_device_tree(struct btmrvl_private *priv)
 		ret = of_property_read_u8_array(dt_node, "btmrvl,cal-data",
 						cal_data + BT_CAL_HDR_LEN,
 						BT_CAL_DATA_SIZE);
-		if (ret)
+		if (ret) {
+			of_node_put(dt_node);
 			return ret;
 		BT_DBG("Use cal data from device tree");
 		ret = btmrvl_download_cal_data(priv, cal_data,
 					       BT_CAL_DATA_SIZE);
 		if (ret) {
 			BT_ERR("Fail to download calibrate data");
 			return ret;
BtrLinux
Privacy Overview
